Does anybody know if YZF 450 A-arms will fit on a banshee? I think ive seen picyures of this but not sure. I mentioned it to my dad and hes interested in buying some. Can some one post pics and give the negatives and postitves about them? Thanks!!
this topic has been gone over so many times. use the search! and yes it can be done
Nope, and nope :blink:
450 a-arms on a banshee?!?! who would do such a crazy thing, i dont think it can be done, unless of course your father is a tv repairman and you have the ultimate set of tools
is that a serious answer or not?? :shrug: lol
well lets see this is my dads second shee and 3rd warrior i also had 3mx bikes and we just completly re-did my truck and are in the process of a street 69 camaro and a drag 72 nova so i obviously think we got the tools. and hes not a tv repair man hes a lift truck mechanic! lol
now from what ive read the 450 shocks are alot nicer and the arms will help handeling and jumping? correct?
Save your money for a nice set of aftermarket Shee arms from Lone Star, Laeger, or if feel really lavish, go Roll Design. There could be no good suspension benefit over going with a set of aftermarket 2+1 arms that are built for the Banshee front end geometry.
Would you put Jeep tires on a Ferrari?
Hell yeah :thumbsup:
so then the a arms are pretty much for look?
and the shocks would be benifical?
the arms will add about 2" wide and 1" forward (maybe it was 1/2") cant remember. The reason they are recommending aftermarket is:
You need to modify the lower arms to fit. This requires cutting and adding a spacer. Not that hard to do.
The front end will sit a little lower. This can be fixed by using different lenth shocks but not sure wich ones ( I am still confused on the complete swap also).
The stock spindles will not allow full movement of the arms. 450 spindles can be swaped also.
There is a ton of info on this, so much that it can be confusing. Do some searching and I hope this will help some also.
Thats just over 2-1/2 wider per side.
I measured the hight on mine before and after, and came out an inch lower which was nice. I bag the shit outa these arms and they do me good.
how is it in rough terrain? I guess you coould always run a taller front tire. I have been looking into doing the swap for the "other" banshee and if I could get it set up right, may consider it for my trail banshee.
Oh....nice bike :thumbsup:
