drag05banshee Posted October 18, 2008 Report Posted October 18, 2008 7MM STOCK CYLINDERS DRAG PORTED WITH INFRAME CPI WHAT CARBS TO USE 35PWK OR 39PWK...THANKS Quote
drag05banshee Posted October 18, 2008 Author Report Posted October 18, 2008 id run 39mm pwk i also like the iea of the 39mm because i can use them later for a biger motor but just dont wana go overkill with this 7mm stock cylinders..wana make shore the 39mm wont hurt performance Quote
locogato11283 Posted October 18, 2008 Report Posted October 18, 2008 i also like the iea of the 39mm because i can use them later for a biger motor but just dont wana go overkill with this 7mm stock cylinders..wana make shore the 39mm wont hurt performance nope you should be good. lots of guys runnin them on 4mm motors. Quote
