Banshee 3 piece Stator Cover Bearing Support Chariot Performance .200$
text me or email me for pics and info 954-839-5155
[email protected]
here is the info from chariot performance
You get the "Fine Machined Finish" complete 3 piece stator cover with bearing support. This includes stator cover, bearing support plate, adapter plate, the custom nut which replaces the stock nut on the sprocket and all stainless fasteners and gaskets.
This is the complete 3 piece kit.
No modification and 5 minute install.
If you don't remove your stator cover to make multiple tuning adjustments at the track then the two piece is what you want. The two piece requires removal of the support plate to remove the stator cover. The three piece allows easy removal of either the support plate or the stator cover separately.
Chariot Performance Transmission Bearing Support
Check all of our listings for the bearing support or stator cover combination you are looking for.
All of our bearing support and stator cover options are interchangeable and modular. You purchase what you want now and upgrade later or purchase the entire assembly now.
Notice that options in our listings are varied and some pictures are just to show the position of the part on the banshee.
Why do I need a bearing support?
Reduces transmission wear by reducing transmission shaft flex cause by modified engines. (increased horsepower through)
Greatly reduces the likelihood of transmission explosions (gears breaking) common to engines producing over 100 horses.
Do I need a bearing support?
Anything done to your banshee to increase horsepower increases wear on your transmission. ex: k&n filter, aftermarket reeds, larger carbs, porting, changing of combustion chamber by use of aftermarket "cool head" and the list goes on
What is unique about Chariot's transmission support?
Ours is completely modular. You can buy one piece at a time or the whole assembly.
The attention to detail and design is unmatched in the industry.
Our products perform as specified!!
We offer options to meet the level of investment you are prepared for.
Is installation difficult?
Our bearing supports are easier to install than any others.
If you purchase the entire assembly, the stator cover and the bearing plate the installation is extremely easy and accomplished in 5 minutes with no modifications required.
If you purchase just the bearing support then you have to use whatever cover you already have to cover the stator area. This is usually only for those on the tightest budget and don't care if they have a plastic stock cover with our aluminum bearing plate. This option requires cutting and epoxying the stock plastic cover. This is very tricky and a pain. Purchase our adapter plate and the process is simpler but still a pain.
Chariot produces the highest quality in the industry and offers the best choice of products at the fairest price
The front cover weighs 9.9 ounces, only 1.3 ounces more than stock PLASTIC cover cut to same size!!! Ask yourself why others don't advertise the weight of their cover. Possibly because they weigh 2lbs and even much more. Ours is designed to be strong and light.
