Mjv420 Posted October 17, 2008 Report Posted October 17, 2008 I currently have a complete rolling chassis from an 89 j-arm frame. I would like to switch over to an a-arm. My question is will all the parts (besides j travel arms) bolt onto the a-arm frame? Like the front hubs and such. Quote
polkaudio Posted October 17, 2008 Report Posted October 17, 2008 it all should as far as I know Quote
Mjv420 Posted October 17, 2008 Author Report Posted October 17, 2008 Thanks Can anyone confirm this? Quote
hylander88 Posted October 17, 2008 Report Posted October 17, 2008 I currently have a complete rolling chassis from an 89 j-arm frame. I would like to switch over to an a-arm. My question is will all the parts (besides j travel arms) bolt onto the a-arm frame? Like the front hubs and such. NO............some spindles are different on newer bikes for the front brake caliper....but if you are just taking every thing off the j frame and putting it on an a- frame it should work...remember all wire harnest are different. for the different year CDI's and starors plugs same goes for head lights.... Quote
351ranger Posted October 17, 2008 Report Posted October 17, 2008 yes it will work. i just did the same thing myself. Quote
Mjv420 Posted October 18, 2008 Author Report Posted October 18, 2008 NO............some spindles are different on newer bikes for the front brake caliper. That was my main concern. but if you are just taking every thing off the j frame and putting it on an a- frame it should work...remember all wire harnest are different. for the different year CDI's and starors plugs same goes for head lights.... I am looking at just getting a standalone A arm frame and use all my 2g harness, lights, coil etc on the a arm frame. Quote
Snopczynski Posted October 18, 2008 Report Posted October 18, 2008 If he keeps his 89 spindles, then it will still work with the front brakes. Quote
Mjv420 Posted October 18, 2008 Author Report Posted October 18, 2008 If he keeps his 89 spindles, then it will still work with the front brakes. The a-arms will bolt up to my 89 spindles though correct? Thanks for the replys Quote
hylander88 Posted October 18, 2008 Report Posted October 18, 2008 The a-arms will bolt up to my 89 spindles though correct? Thanks for the replys yes they will, also when i was checking at our bike shop on a-arms to j-arms the bottoms where the same part #'s. Quote
Mjv420 Posted October 19, 2008 Author Report Posted October 19, 2008 yes they will, also when i was checking at our bike shop on a-arms to j-arms the bottoms where the same part #'s. Thanks, that was my main concern :thumbsup: Quote
