i just put myb engine together..set up is..
4mm crank
cool head 22mm domes
v force 3s
timming plate at plus 4deg
reed spacer blocks
34mm mikuni flat slide carbs..btw this engine is in a road bike
prob is that at about 4thou rpm the bike seems to pulsate.. almost turbulant like, its quite odd i never experienced it b4 if i rev straight past it its fine but 4tho is about crusing speed so its a real pain.. it doesnt miss fire or seem to be starving it just feels like it things i have tried
removed the spacer blocks no different
raised the clip which richened it up..it was better but still not all that good at the bike was too rich and fluffy...could it be the timming i think i will try stock timming tomorrow..anyhelp at all would br great thanks
sea level, 22 pilot, clip second from the top 270 mains..i havnt really got around to jetting the main jet as the bike is being run in and is a lil rich bottom and mid is good and crisp plug colour good too..but just that odd resinence
What's your elevation, temp. and current jetting?
