klemet banshee Posted October 15, 2008 Report Posted October 15, 2008 how much gas milage can i get from this? its a 36mm carb Quote
LS1Inferno Posted October 15, 2008 Report Posted October 15, 2008 how much gas milage can i get from this? its a 36mm carb less then the stock dual carbs. you are moving MORE air and fuel in , and even a smaller carb it still takes the same amount of fuel to make the motor run as dual carbs. Quote
Snopczynski Posted October 15, 2008 Report Posted October 15, 2008 less then the stock dual carbs. you are moving MORE air and fuel in , and even a smaller carb it still takes the same amount of fuel to make the motor run as dual carbs. It doesn't seem to be different from duals at all. Quote
