BOSS LX Posted October 9, 2008 Report Share Posted October 9, 2008 This is a fresh build, and I have no power to the coil. Thanks for ANy help~!!!! Quote Link to comment Share on other sites More sharing options...
desert nut Posted October 9, 2008 Report Share Posted October 9, 2008 This is a fresh build, and I have no power to the coil. Thanks for ANy help~!!!! might check out ground by cdi or check flywheel Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted October 9, 2008 Report Share Posted October 9, 2008 So no spark? There is no test for checking voltage to the cdi, just ohms. If it ran when you took it apart, you did something wrong putting it back together. Double check all the connections and installation. Quote Link to comment Share on other sites More sharing options...
hylander88 Posted October 9, 2008 Report Share Posted October 9, 2008 So no spark? There is no test for checking voltage to the cdi, just ohms. If it ran when you took it apart, you did something wrong putting it back together. Double check all the connections and installation. check the stator for damage if you use the wrong flywheel puller you could have done that... Quote Link to comment Share on other sites More sharing options...
