So this winter im planning on tearing her down and powder coating the frame and removing th paint off my plastics, their black and white which is what i whant, im just not sure how to remove paint off plastic. What have you guys found that works without ruining the plastics? Thanks guys
i was thinking more along the lines of aircraft remover but im not sure if it will melt my plastic if i get brave maybe ill try your suggestion thanks for the response :beer:
EASY-OFF oven cleaner. learned that back in my model car building days. swear to god it works!
like the stuff that comes in the spray can? no way . . .you really have tried this
  • 2 weeks later...
No no no my friend. I had my rims painted black on my car. After the summer was over i wanted them back to stock. My buddies dad has a body shop and he said to try some aircraft remover to take off the paint. Well it sure did take off the black paint along with the clear coat on the rims right down the bare aluminum. I ended up having to buy new rims that following spring because they were so ugly and look like they were put threw a grinder. If it could take off clear coat on rims I'm pretty sure it would destroy plastic without a problem
Easy-off is the shit, but just be carefull it'll strip powder coating too. Also use it in a well ventilated area with gloves, it is a nasty chemical.
enjoy!
I think acetone is one of the cleanest strippers. You just have to watch how long you leave it on for. Depending on the condition I'd probably use paint thinner.
I find the best way to prep plastic for paint is with the red scotch pads (the auto ones) to get a good scuff on it before painting again. The gouges may need sanding if any.
Unless you are going to try and buff out the plastic then that is whole nother story.
Either way I think you will need to refinnish the plastics.
