Im needing the following,
Wireharness 2GU for an '87
Ignition switch 2GU '87
Killswitch/lightswitch control 2GU '87
If you have all or one let me know.
I have all of it from a 95 in good working condition.
Ignition switch w/ key and dash peice
Headlight switch works good had small crack in bottom which was repaired w/ epoxy to seal it.
wire harness has one wire that goes to the stator cut and spliced but the end is still in the plug and could be tied back in the plug if wanted. My wire was out of the plug on stators end so it was just wired in direct. (no cdi or coil)
$60 shipped in the 48
That wire harness is different from what I need, I need a 2GU wire harness.
Thanks though :biggrin:
I've got one off an 89 I just bought to part out, pm me if you are still looking.
Dont need wireharness or key switch anymore.
I do need a bolt for the swingarm and a good set of handlebars
I've got a few handle bars laying around. What type you want, I know I have some renthals out there
