POORBOY350 Posted September 21, 2008 Report Posted September 21, 2008 my cuz has an 02' that is built and it isnt firing. we switched the coil out and that wasnt it. so i guess it is left to the cdi box or stator, right??? when we tried to pull it off the lights came on but no fire at all. so how/ what do we check to see what it is thanks. Quote
LiftdT4R Posted September 21, 2008 Report Posted September 21, 2008 Did you check and see if you have a spark? Pull one plug at a time, and turn of the gas, put the plug in the boot, but let the end rest on the cylinder and then kick the bike. You should have a fat blue spark. If not, then its an electrical issue. If you do your problem lies elsewhere. Quote
POORBOY350 Posted September 21, 2008 Author Report Posted September 21, 2008 Did you check and see if you have a spark? Pull one plug at a time, and turn of the gas, put the plug in the boot, but let the end rest on the cylinder and then kick the bike. You should have a fat blue spark. If not, then its an electrical issue. If you do your problem lies elsewhere. Yea i did that and it didnt have a spark. so where do i go from there what do i check. Quote
BlntdEyez Posted September 21, 2008 Report Posted September 21, 2008 Get a ohm meter and then read this http://www.bansheehq.com/index.php?option=...2&Itemid=28 Quote
POORBOY350 Posted September 21, 2008 Author Report Posted September 21, 2008 Thanks thats pretty much everything you need to know. i have another question.... i have a cheetah cub motor on my bike with timing advanced 4 degrees or whatever and im wondering if i can just bump it up to like 5 or 6 and go with it. or what are the things i have to do in order to do it thanks. Quote
Tim Potteiger Posted September 21, 2008 Report Posted September 21, 2008 Thanks thats pretty much everything you need to know. i have another question.... i have a cheetah cub motor on my bike with timing advanced 4 degrees or whatever and im wondering if i can just bump it up to like 5 or 6 and go with it. or what are the things i have to do in order to do it thanks. I have seen Cubs at +8, but I would stay at 4 personally. Quote
POORBOY350 Posted September 21, 2008 Author Report Posted September 21, 2008 (edited) I have seen Cubs at +8, but I would stay at 4 personally. only reason im asking cause someone told me they loved timing... idk much about them. and im not even sure what 2 degrees would do...but i want the bike to be as reliable as posible so i am gonna leave it alone maybe change pipes. Edited September 21, 2008 by POORBOY350 Quote
