After doing it by eye, and then using the tool, Ill never go back to doing it by eye. Well worth even the 55 IMHO
Could you tell a difference or just easier on the eyes? Cause I eyeball them too and think I got a pretty good eye for shit like that, double check, triple check,and so......
as said before.....
"to be honest MJ. i was led to believe my eyes were good enough. seeing is believing right? well, i got the tool and i was way off. shee even runs better. i recommend it for all banshee riders. they were designed for VW`s but perfect for the banshee. "
Do both ni**les raise with the flick of a thumb? I thought not! How do you detect movement synchronously then? Get the gismo!
SP
Ive never used one of those. I just use my eyes and some common sence. If you have the box off or pods off you can see with the smallest touch of throttle if they left in sync or not. And use a feeler to make sure the idle screws even too, before lift sync.
That is a great tool and well worth the price.
Start by using it to set idle, then open them up about a 1/4 of the way and check again.
Counting turns on adjustment screws is nothing compared to using this tool.
It works...For drag racers or Joe Trail Rider....
I used my eyes too, and will sit there for 1/2 hour triple checking it..
But why? This takes that guestimate out of it.
