i have a 87 banshee with toomy pipes rad valve 3/8 reed spacer stock air box with lid off k&n filter boost bottle stock pilot jet 280 main jet needle clip in stock postion air mix screws 2 1/2 out. it idles good but breaks up at full throttle if i hold choke out alittle bit it will run better up on full throttle .i tried turning air mix screws in till 1/2 out and it ran better .should i have bigger main jet? or maybe bigger pilot jet? or move needle clip?
bigger main... try a 320 then a 300..
yeah this wont cause it to run bad (unless it has already cracked the intake boots) but loose the boost bottle because well it can crack your intake boots and make it go lean and burn up
