GrMeyer Posted August 29, 2008 Report Share Posted August 29, 2008 ok here is what i need some info on. I still have the Tors on my carbs. So the Kits is around $50 and a new set of 30mm OKO is like $200 shipped. Should i stay with the stocks or move up to the 30mm. I have fmf fattys. pod filters. noss head with 20cc tail port. +4 timing. I ride a lot of fast trails and the hell out of the dunes with the daily ride to the drags and back. I want to keep it dunalbe but have that one time of drags for fun. Would I be better off trying to find some 28mm OKO's? I just want to leave room for later upgreades to like a 4mil cub when this motor has its time to retire. And just a thanks to All for all the great reading and help of others probs and tips to help Quote Link to comment Share on other sites More sharing options...
bigboybanshee Posted August 29, 2008 Report Share Posted August 29, 2008 Stick with the stock carbs on your stock cylinders. If you go to a cub later, I wouldn't recommend anything smaller than 35's, which would be too much for an un-ported stock cylinder engine. Just my opinion Quote Link to comment Share on other sites More sharing options...
jharader Posted August 29, 2008 Report Share Posted August 29, 2008 dont waste your money on the oko's, the fuel inlet and bowl design are shit... No need to go bigger carbs from what you've stated as mods, 28 at most if you decide you just HAVE to have new carbs but dont give yourself the same headache i did with that junk Quote Link to comment Share on other sites More sharing options...
GrMeyer Posted August 30, 2008 Author Report Share Posted August 30, 2008 dont waste your money on the oko's, the fuel inlet and bowl design are shit... No need to go bigger carbs from what you've stated as mods, 28 at most if you decide you just HAVE to have new carbs but dont give yourself the same headache i did with that junk Hey everyone thanks for the great input. I guess ill just get the tors kit and call it good. anyone know of a good all in one kit from who to buy from? Quote Link to comment Share on other sites More sharing options...
Mjv420 Posted August 30, 2008 Report Share Posted August 30, 2008 There are a couple different kits out there, toomey is one of them. A complete kit should consist of the throttle cable with carb tops (cant remeber if it comes with slides?) idle screws, drill bit and tap. It makes everything alot easier to fool with. Quote Link to comment Share on other sites More sharing options...
GrMeyer Posted September 17, 2008 Author Report Share Posted September 17, 2008 There are a couple different kits out there, toomey is one of them.A complete kit should consist of the throttle cable with carb tops (cant remeber if it comes with slides?) idle screws, drill bit and tap. It makes everything alot easier to fool with. Found a Vito's Tors kit on ebay for $60.00 shipped....Anyone know of this kit. and if there are any other kits i need to be looking into? Thanks Quote Link to comment Share on other sites More sharing options...
