shee4speed Posted August 28, 2008 Report Posted August 28, 2008 Has anyone tried the FAST caps that let the carbs open farther? Do they help? Quote
TeamRealtreeHD Posted August 28, 2008 Report Posted August 28, 2008 Has anyone tried the FAST caps that let the carbs open farther? Do they help? I got them on my PWK 33mm's... A+ on them. They really do the job. Screw right in and let the slides open all the way. WOT is always a plus Quote
shee4speed Posted August 28, 2008 Author Report Posted August 28, 2008 I wonder why they dont go WOT from the factory. Thats gay! Quote
250psd Posted August 29, 2008 Report Posted August 29, 2008 I was on FAST's web site and could not find them. Could someone post a link? Quote
TeamRealtreeHD Posted August 29, 2008 Report Posted August 29, 2008 (edited) 4th item on right side.... in with the springs. Those springs are great too.... Gold tops are stock on Keihin... you can see the length difference http://www.farmandsandtoys.com/products.as...set=50&cat= Edited August 29, 2008 by TeamRealtreeHD Quote
250psd Posted August 29, 2008 Report Posted August 29, 2008 Oh. So it's not the actual cap. It's the cable adjustment screw? Quote
TeamRealtreeHD Posted August 29, 2008 Report Posted August 29, 2008 Oh. So it's not the actual cap. It's the cable adjustment screw? Yes, well worth the change to buy them. Well well worth it! Those springs as well. If your throttle is rough, get them. Out performs a cut stock spring from Keihin by a long shot. Both those items are top notch Quote
shee4speed Posted August 29, 2008 Author Report Posted August 29, 2008 thanks for clearing that up realtree.I thought it was the caps also. Anyways I have the brass adjusters but it still doesnt go full throttle. I'll post pics. Quote
TeamRealtreeHD Posted August 29, 2008 Report Posted August 29, 2008 (edited) Hey, no problem man. Yes, those brass ones are tough to get to go WOT. I don't think it is possible. The longer silver ones that are next to the gold ones on that site picture are the ones you want. They screw right into the carb black cap, just like the stock keihin adjuster. They are extremely easy to adjust, and synchronize too. They work very well with any cable as well. I use motion pro cables, but I know a guy who just got them that uses other aftermarket cables with great success as well with these new taller adjusters. Definately the way to go. For the price for the two new adjusters, it is a good investment Not to mention Jeff will have them on your doorstep the next day. I am halfway across the country and they were here in less than 24 hrs from the time I got off the phone with him. Edited August 29, 2008 by TeamRealtreeHD Quote
shee4speed Posted August 29, 2008 Author Report Posted August 29, 2008 oh damn heres the pics.Kinda blurry but you get the point Quote
TeamRealtreeHD Posted August 29, 2008 Report Posted August 29, 2008 Yes, you need those caps then. Hold on, I will go snap a pic of mine. Gimme 10 minutes Quote
TeamRealtreeHD Posted August 29, 2008 Report Posted August 29, 2008 Here is just one side on my PWK 33's. I held the camera with the hand hand, and held WOT with the right. And a picture of the tops of the carbs with the taller adjusters, with the cables attached. Quote
shee4speed Posted August 29, 2008 Author Report Posted August 29, 2008 dude thanks for your time.I will be on the horn with Jeff 1st thing in the morning.Also when you fire your bike up cold do you have to pull both chokes? I havent got my new carbs on yet. Quote
TeamRealtreeHD Posted August 29, 2008 Report Posted August 29, 2008 (edited) I am more than happy to help man, no need to thank me. This is sometihng that you really can't visualize. You must see to know the difference. Jeff will have them to you the following day. I think he UPS's his shit. When I fire my bike up, I don't even use a choke. None. At least not in weather above 50-55 degrees. But when you do need a choke, usually only 1 is needed. Both carbs are the same, so the carb on the left has the choke on the left, and so does the one on the right. That means ther one on the right isn't that easy to get to. But I can get to it no problem, just not as easy as the left sticking out right there. Only one is needed though if you need to use it. I haven't needed it yet though. What is wrong with those PWK's you have now? Or are you going to a different size? Just curious Edited August 29, 2008 by TeamRealtreeHD Quote
shee4speed Posted August 29, 2008 Author Report Posted August 29, 2008 Those are new PWK's.Just got them.Pulled the stockers off.And now putting these on but want everything right.Found out about the full throttle thing and went hhhmmmmmm. Quote
