bansheerabbit
Everything posted by bansheerabbit
<= The WINNING post LOL
G'Day all I have just received a set 32mm Mikuni round slide carbs and wondering what size get would be a good starting point 2006 Banshee CPI Inframe pipes drag ported Stock 64mm bore +4 Timing VForce 3 reeds Coolhead 19cc Domes 98 or 100 octane pump gas 32:1 Castrol TTS oil Air filter - ProDesign foam filter and foam outer (oiled) mounted to stock air box and modified lid half open Elevation 200 feet Temp range 60-80f Thanks for yur help inadvance Carbs came with 200main jet and 35 pilot
Adjustible timing install / Flywheel Removal
bansheerabbit replied to magz's topic in Technical Info
Cant get flywheel off. I have had problems before on other banshee's but was hoping this engine would be easy as it has had less then 30mins running from new. Open to ideas on removal - try freezing it???? Thanks in advance -
G'Day all I have done a search on shift star and came up with lots things but no templete or similar on what it should look like after modification. I dont mind if I have to buy one but would much prefer if I could do mod myself so any info on modification would be great Cheers Rabbit
Lots of Banshee Parts! will sell cheap.
bansheerabbit replied to Bantrx95's topic in For Sale - Parts & Accessories
2003+ wiring harness (square Plug) - need reg, coil, cdi etc etc- 12 replies
- Used Banshee Parts
- Banshee
(and 5 more)
Tagged with:
I'm in australia and I got my NOS kit from Cold Fusion Nitrous in the states. I do have a complete kit minus the bottle if you interested, kit still in shrink wrap. Details off kit below http://www.coldfusionnitrous.com/nitrous-systems/products/796-dual-carb-motorcycle-kit-10-100hp-w2lb-bottle-line-cfn-1401.aspx Can post a photo off kit tomorrow when I get to workshop
Chasing a 2003+ wiring harness/loom complete (Square Plug) need everything i.e coil, regulator etc etc I have both STD and a DYNA FS CDI to suit 2006 shee but if you only want to sell complete I would still be interested
2013 November BansheeHQ Play Day
bansheerabbit replied to locogato11283's topic in Riding and Events Forum
Little bit more notice and I might have been able to arrange freight/airfares from AUS Just hope you guys have a great day riding -
Hi Guys I'm chasing a year 2003+ wiring harness I need everything ie, coil, reg, plug leads etc etc DONT NEED black box(have a Dyna FS) also chasing a thumb throttle (dont need card cables) Thanks in advance Downside location AUSTRALIA - I have had pleanty shee parts shipped b4 and freight not to bad. Deariest thing would have been $150us shipping cost for full set fullbore plastics , CPI pipes came in at $80us frieght. Al items here in under 1week Cheers Rabbit
Hi All, I am in the process of setting up my 07 banshee as a asphalt drag shee. I have no started the engine since full rebuild - 64mm pistons (wisco) ported cyclinders, std stroke Hot rods crank, lockup clutch (rest in signature) I have Nitrous and would like to run on alky. 39mm PWK carbies (use bike between 0-600 feet) temp 65-80 What size jetting should i use for the above set up? What alky oil ratio? Also on cars you need to enlarge ring gap when running alky and nitrous is it the same with banshee's? Also any other info on how to set bike up would be greatly appreciated i.e suspension etc etc. Have state titles in 4 weeks so i would to go out and kick some butt! Thak you very much Cheers Rabbit
Hi all, Been waiting 2 weeks now for my new Banshee to arrive, finally got here today. I ordered heaps of parts for it the day I ordered bike. CHECK out sig for some the items being fitting tomorrow to bike. As you will notice I have another couple shee's in stock. You can never have enough can you? I will port, weld crank etc later guy's. Did last port job my self, bike runs great heaps more all over. Anyway happy and safe riding. Rabbit
THE NEW 2007 BANSHEE It's back but not in the US
bansheerabbit replied to arubianshee's topic in General Banshee Discussion
07's are still available in Australia. I have just ordered a new one, arriving next Friday 28 Oct. Leaving dealers to bike shop for parts to be fitted same day then time to run her in. -
I smoke both!!!! Perfer to have my daily green intake!!!!! Best thing happened last weekend I was outside having a joint and the sexy bird from next door stuck her head over the fence and asked for some. Needless to say I invited her in and we had a session from hell. I could hardly move by the time she left. I see her every night now for smoke still trying to get in her pants proberly tonight or tomorow depends on how stoned/pissed we get!!!!!. Skunk, Super Skunk, Bubble Gum, Northern Lights, Four Seasons are some of the better buds we are producing now and years gone by so whats happening in the rest of the world. RABBIT
How Many Aussies Are There On Banshee Hq?
bansheerabbit replied to 02_banshee's topic in General Banshee Discussion
HI there, Are any off you into drag racing? I am going to drag my RZ-Shee this season - just getting my std swingarm lenghtened +6inchs , hoosiers arrived 3 weeks ago and should be ready to go. Might order NO2 before season starts. My best time with my other banshee was a 13.2sec over the 1/4mile Rabbit -
I am a Aussie - Hobart, TASMANIA. Rabbit hey - banshees and beers I go ride-a-bout to hard to walk when pissed/stoned -
Thanks for replies guys. I found the locating pin lst night deep inside top of left piston. Order today a new wiseco piston kit. I have another std head but I have a coolhead on ordered so will just tidy up damaged head for now - only has about 20 marks from pin in it. I was looking at my 100thou over RZ piston kit last night from wiseco and noticed that one of the locating pins was a bit lose, before I install the new pistons I will loctite the pin in place or should I return to place of purchase? The only time I have had wiseco's break at skirt near window is when I have opening windows up a lot more than I should have. Rabbit
Hi All, I pulled banshee apart this weekend due to lose of compression. 130 right and 125 left with 20thou off head should be around 150 I think. I thought I had broken a ring, the problem is that the left piston the pin that locates the lower ring fell out and made a mess of head and piston but didnot leave a single mark on cyclinders still see hone marks from 6 months ago (new wiseco pistons installed at same time). I have just ordered a new set of rings and will be back together shortly I plan on just filing top of piston flat again and diegrinding head. Has anyone else had this happen??? Rabbit
Hi Hasty, Do yo have the rest of the RZ Engine? If so convert bike to RZ power might be cheaper than getting a flywheel shipped in. If you do get one shipped get a lightened one you wont be disapointed. Taken 250grams of std banshee flywheel and 220 of RZ flywheel amde a big difference to bike reving up quicker Rabbit
Hey everyone, I am just trying to get things started in my area and was wondering the same as THE WOLF about the chrissy tree light/timing system!! or does someone on here have a plan on how to make them. Be good if I could find a 12 volt system otherwise will have run an inverter. Rabbit
Anyone Have Raptor Starter Problems?
bansheerabbit replied to JTQuad's topic in General Banshee Discussion
My Craptor is giving me the shits!!!!!!!!!!!!! I am having electrical problems from starter motor to cdi. I've had it at 2 auto electricians and they can not locate the break in wiring harness. The bike just stops as you are riding it. All connections are clean etc but there is something not right. Died on me again on sunday. Just as well I took my banshee along also!!!!!! LONG LIVE THE BANSHEE Rabbit -
Check the hex head bolts that bolt the tie rod ball joint to the hub, Mine cracked the welds and came loose which cause a similar thing to happen. Rabbit
I am going to use my RZ tranny in my RZ Shee. I will let you know in about a month or 2 on how it preforms. Just got last engine peice last week so time to put together. I will be using the RZ-Shee for mainly drags so the longer legs should help. Rabbit
I would be interested in signing up depending on price. What sort of things do you have planned for people out side of the US in entice them to sign up???
I am running Repsol at 32:1. Does anyone know anything about Justin Brothers 2Cycle oil???? (Had some given to me not sure if any good for Banshee!) rabbit
