coleman
Recent Profile Visitors
1,558 profile views
coleman's Achievements
  1. Hi, I’m looking to see if anyone has the radiator shroud and gas tank shrouds in the greenish blue color, specifically from the 1992 model year. Thanks
  2. Tors was removed by the PO and worked okay when the old carbs worked, the carbs are synced too. Why do I need to take the lid off? Thanks.
  3. Ok I used some automotive grade caps to cap it off now but it’s still not idling. I can keep it running if I rev the piss out of it but if I let it get a lower rpm is bogs out. Chokes on it idles fine
  4. I thought I had them capped off well enough but I went to start it today and that happened to me.
  5. Hey guys, I recently installed new keihin pwk 28's onto my banshee, and I cannot get it to idle with the chokes off. I have vforce4 reeds, t5s, stock air box with k&n filter, cool head, tors deleted. My pilots are at 45s right now and my elevation is about 800 feet and 50 f degrees. Here is a video of what i'm talking about. Idles a little high with chokes then I turn them off, it revs high but wont idle down low, and it doesnt like throttle https://youtu.be/u4AiCFLGwjY I'm not super mechanically inclined so please be patient with me....
  6. The bike started perfectly with the fluid. idled just fine after that
  7. Got the shocks on Ignore the shitty graphics Sent from my iPhone using Tapatalk
  8. Now I’m confused. Before I took it apart went to go start it it started first kick. Today it’s 75 out and the day it didn’t start it was about 65. Do I still take it apart? Also I recently acquired some Elka stage 3 suspension. What would you scale the difficulty to put them on? Sent from my iPhone using Tapatalk
  9. Starter fluid i used has lubricant i'll try to take the carbs apart. Pray for me and hope i dont screw something up
  10. I got it running using starter fluid, do the plugs look okay? Sent from my iPhone using Tapatalk
  11. Not sure, bought it last spring and it ran fine until now. Anyway to see? Sent from my iPhone using Tapatalk
  12. Noob here Few days ago bike wasn’t starting, I checked the plugs and they looked very worn, so I put a new set in and it started first kick. I rode the bike 2-3 more times in between that and now it won’t start. These are the plugs I just put in Any ideas? Bike has toomey t5s, tors removed Sent from my iPhone using Tapatalk
  13. Yeah but I don’t think anyone should think they will have to drop 10,000 on their first banshee that’s for sure Sent from my iPhone using Tapatalk
  14. Some of these guys are crazy You don’t need to spend 10k on a bike to have fun. I would much rather have a stock Banshee than a banshee with 10,000 put into it, I like going full throttle and not just tapping the gas. But that’s just my opinion, if you wanna go fast, which a stock banshee is still pretty quick, drop 10k on one Banshees are fun because of the powerband and the low center of gravity compared to the raptor IMO but the yfz has a pretty wide base so it’s all up to your preferences Sent from my iPhone using Tapatalk
  15. Stock carbs and stock box. Unsure of jet size but ran fine 3 weeks ago in same weather and elevation Sent from my iPhone using Tapatalk
