About nickon
- Birthday 02/02/1989
Gender
Location
Belgium
Recent Profile Visitors
974 profile views
nickon's Achievements
How fancy? Got an example or something to show what you want it to look like? I've done some Photoshop in the past but not sure if I can help out. Sent from my Nexus 5 using Tapatalk
I'd recommend this also. Had the exact same issues you described and this did the trick for me as well
I do have some other questions though. Question 1: electrical It occurred to me twice that I fired up the bike first kick, idling well, putting on the lights, leaving off with it and having it shut down on me, not being able to kick-start it again. This has never happened to me with the lights off, or when I first leave off with the bike and then turn on the lights while driving. Because of this it has me thinking it has something to do with the stator (lights draining the spark plugs from firing at some point). I did a stator reading using a multi-meter and this came out Ignition coil (red to green) Recommended: 13.7 - 20.5 Ω Actual: 17.9 Ω Pickup coil (white-red tracer to white-green tracer) Recommended: 94 - 140 Ω Actual: 115.1 Ω Lighting coil (black to yellow) Recommended: 0.26 - 0.38 Ω Actual: 0.095 Ω Maybe worth noting that in the "hi" position, only one of the lights is producing light, the other is not. In "lo", both are working just fine. What to do next? Question 2: cooling I was letting the bike idle for about 10 mins while getting my helmet and jacket with the outside temperature at 25°C. When leaving off with it, the radiator started to fume due to very hot coolant being pumped into it. I immediately stopped and shut down the bike and let it cool down for a while. Then left off with it again without any issues. It has me worried though. Is it normal that it heats up that quickly when stationary? I assume the water pump is only running when the bike is in gear and I’m actually driving? Is this normal? Even though this might not be a solution to the problem described, I'm thinking about switching out the radiator for a new, over-sized one. The original one seems pretty beaten up to me, what do you guys think?
Ok, after finally getting al parts in and inbetween chores and getting married, I managed to get some work in on the banshee Removed parking break and it's electronic connection and installed an ART end cap. Removed the TORS (on top of carbs + the brain) and installed new Moose throttle cable with direct end caps on the carburators. No more rev limiting has occured since! After setting the floats to 21.00mm both carburators were still leaking / overflowing fuel. Installed carburator repair kit on both carburators and they stopped leaking. I'm convinced this is due to the old main jet seals being worn. I really needed to squeeze in the new main jets compared to the old ones, which dropped in (and out) easily. Synced the carbs 5 kg/h (idle) and 10kg/h and it's idling well now, no more spontaneous shutdowns when idling so far.
You can tell I'm new to carbs and wasn't paying attention? [emoji28] Just unscrewed the pilot jets and they're 25. Seems to be the correct setup then? Sent from my Nexus 5 using Tapatalk
Took some pictures of the main and pilot jet because they're quite hard to read imo. Main seems to be stating 200 Not sure about what the pilot number is
Pulled the carbs of the bike and took them apart. They looked pretty clean to me. Main jet seemed to have the number 1.9 on it and the pilot jet 2.8, is that possible? Are these stock jet sizes? I also measured the floats before I took em off and they were both set properly at 21mm (although I thought the left would be off because it was leaking fuel after riding the bike). Jet needle was also set properly at the third groove on both carbs. I also pulled the T.O.R.S. off and gonna order a delete kit along with the carb sync tool so I can put the carbs back on without T.O.R.S. Is there anything else I can check in the meantime (parts shipping from US to Belgium will probably take a while). Or should I just wait untill I'm able to put the carbs back on without the T.O.R.S. and see if that resolves the issue? Thanks already.
Pulled it this morning and took the bike out for a minute, didn't do the trick... When I bought the bike, I brought it to the dealer which told me he cleaned and synchronized them. If he actually did is another question (as he didn't really seem that trustworthy to me afterwards), so I don't know for sure. Also no clue what my current jetting is, how do I get that information? (I'll read up on carbs...) As far as the FMF stickers go I don't know the answer either. It had a bunch of stickers on them and when I bought it, it was completely stock. I have no information on the seller selling parts seperately. Do you think some carburator hickup can cause this kind of behavior midway down a ride? Anyway, never a lost cause to clean the carbs. As you mentioned the plugs look wet and I do sometimes have trouble kickstarting it so.
Thanks for the pointers Schweetz, I took my Clymer and started troubleshooting. What I checked already: SPARK Don't seem particularly fouled I guess? (see pic below), cleaned them nevertheless. Pulled out both spark plugs, grounded them against the cylinder and kickstarted the bike. Both give a nice blue spark. They're brand new. COMPRESSION Did a compression test. Same compression tester, some pressure level on both cylinders as the test I did a couple weeks ago. (see pics below, left and right cyl respectively) FUEL Old fuel from when I bought the bike was still in the tank. It was down to reserve level when the shit hit the fan. Wondering if this is a coincidence or not? Anyhow, drained the tank and put in freshly mixed fuel. Checked the venting tube on the fuel tank. It's open. Pulled of the fuel line, both run fuel nicely to the carbs. Left carburator is leaking fuel from the overflow tubing. This was already the case before. How can I check / make sure that both cylinders are getting fuel without pulling off the carbs? I know fuel is reaching the carburators from the test above. PARKING BREAK CONTACT The Clymer mentioned the electric handbrake contact would limit the rpm of the engine. Perfect explanation I figured, because I pulled off my back- and parking brake for a revision and it still isn't on yet. Unfortunately this is not the problem. Just fired up the bike and purposely played with the parking brake contact while driving. When I break contact, the engine rpm is limited even further. When the contact is closed again, the engine revs 'freely' to a point where it stalls at a later point like before. The engine feels quite shaky and it isn't really delivering throttle smoothly, more like chugging / bouncing along... Any advice you guys can give me that would point me in the right direction is appreciated. Thanks, nickon
Rebuilt the back brake, but slightly damaged the rubber that is sealing the piston from the handbrake, so it started leaking there when bleeding the brakes Anyone knows if I can get the seals seperately at a fair price (shipping to Belgium)? If not, I'm probably ordering a rear brake rebuild kit or going for a new (yfz / r700) caliper immediately. So, 34°C over here this weekend, got my license plate and the bike insurrance ready and took her down the road for the very first time. It was fun while it lasted, but it seems to me like one of the pistons blew up after just a couple hours of riding... Suddenly the engine started shaking and the throttle response just dropped. Putting down the throttle doesn't rev the engine anymore and it sounds like only one piston is 'knocking' the engine properly. See the video below. Two questions How to determine what's wrong? I guess start by doing a compression test on both cylinders and see what I get out of that. What could be the cause of this and is there any way I could have prevented it? Thanks, nickon
Stripped the back brake, everything seems intact and fine after it will be cleaned. The parking break was pretty rusty though... Cleaned it using WD-40 and compressed air without disassembling it. I didn't find any instructions in Clymer and didn't see a clear way to dismantle it? The brake caliper bracket is still on as you can see in the picture above. The bolt thread is completly ruined... Any thoughts on how to fix that without buying a new bolt / bracket? I could also just leave it and clean the caliper with the bracket still on. But there is a rubber seal in there along with the bolt, so the break cleaner probably won't do it any good... What's the use of that seal any way? Also, any thoughts on the compression test and the spilled coolant?
Did a clean (or should I say the first clean ever) of the banshee. Damn was she dirty. There's still some grease/dirt left in places I couldn't reach entirely, but she looks alot cleaner already. Anyhow, lots of surface rust on things, but didn't notice anything particularly broken or bent or anything at first sight besides the stuff I will mention below. First off, I did a compression test on both of the cylinders, this is left and right respectively as you can see, both at about 115 psi. I'm at 125 feet (38m) above sea level and the motor should be all stock. Compression is not really as high as it should be I guess? But I'll let you guys judge and give advice on that. For the back brake, I managed to get the broken wrench bit out of it after dismounting it from the bike (see first pic). It seemed to be quite loose in there from the start but it was still quite stuck and tricky to get out with a pair of pliers because I couldn't grip the broken bit firmly enough. The thread which had the broken bit inside it seems pretty worn out. Took some pictures to show you guys the overall state the break caliper is in. Would I be able to salvage and revise it or would you advise me to buy a new break caliper? While inspecting the back break a bit further, I noticed a different part above the rear brake lever that seemed to be looser than it should be or might even be broken? That is, the plastic(?) part that is touching my finger. What is it exactly and what is it's purpose? Now for some laughs and giggles. I disconnected the radiator hose from the clutch cover because I was worried that I introduced some water in that hose after spraying my radiator (from a distance) with my pressure washer. Boy, was there some fluid in there (obviously). I disconnected the hose only for a brief moment (not even a second I guess) and a gulp of coolant leaked out of it... Of course a banshee is liquid cooled but yea mistakes were made Am I safe as long as the coolant reservoir near the back of my seat is still topped of? That's the same cooling circuit, right? Because I noticed there's also a cap on the radiator itself that can be unscrewed. Is there a need to 'bleed' the cooling system after such a mistake or is there no risk involved in possibly introducing some air bubbles? As I rinsed off alot of dirt but also grease on the bearings, I should probably regrease all the joints? Also for replacing some of the bearings, I was wondering if aftermarket A-arms come with bearings included or not? And are they the same as stock bearings? Just a matter of judging whether it's worth it or not to replacing the bearings if I plan to upgrade the A-arms soon.
My Build Thread, Redline 10mil Super Serval Cub on 110.
nickon replied to PaymentPlan's topic in General Banshee Discussion
Sick exhausts controls! I do agree it's a bit of a shame about the rust on them new shinies. I probably couldn't resist brushing it of and putting some WD40 on my brandnew goods though, especially if it only takes 5 mins. Do you have a different picture where we can see the exhausts in full? I'd love to see that -
Is it possible a stock 99 wouldn't need rebuilt?
nickon replied to ckylesworld1's topic in General Banshee Discussion
Good luck! -
Thats really useful info, thanks Ragun. I looked up the Cuervo dual piston rear brake, definitely isnt cheap! Verstuurd vanaf mijn Nexus 5 met Tapatalk
