Deezil
Everything posted by Deezil
  1. Hmm, trying to remember, I want to say there was, but dont remember 100%
  2. Amzoil 40:1 K&n Sent from my iPhone using Tapatalk
  3. Ok. I'll look it over. Thanks. Sent from my iPhone using Tapatalk
  4. how do I test that? Im basing my findings off it loading up at idle, watch the video
  5. Still trying to understand why going richer is going to help my rich situation, can you elaborate?
  6. Saturdays run, seems decent now, except at idle, thoughts? 280 main jets, 25 pilots
  7. It is 40:1 amzoil dominator
  8. Tons of smoke. Have to throttle up to clean it out.
  9. Ok. That makes it leaner on the bottom? That's what I need.
  10. As rich as it is I should go bigger on the pilot? Yep. Synced. Idle mixture screw I think Ive been using backwards. Been turning in to lean. But it's out. Lol. Yep. That's it.
  11. Gotcha. It was way too rich before so I'm on track with the needle. You don't mention the low mixture adjustment screws. I'm trying t figure out why my mods don't require more fuel I guess. 280 main jet and a 25 pilot jet should be too lean. Right? Sea level.
  12. Moved the clip to the top of the needle, now it just seems really fat on the bottom end but once you get moving it cleans up and goes like a mofo I have the idle mixture needles at half turn out and still seems to lead up at idle. Normal? Maybe my needles should be changed. I'll try to get numbers off them soon. Sent from my iPhone using Tapatalk
  13. Ok thanks. I have not changed anything on this quad. Other than removing tors. I didn't add pods. It came that way.
  14. uncut with the fenders on yet, like stock. Im in Washington. Thanks
  15. Understood, This is how I got it, Im just trying to make it run right. I wonder if it has a weird needle in it or something... My jet set comes tomorrow, and it has a needle with it.
  16. In hindsight I think I went the wrong way... I lowered the clip to center, so it RAISED the needle, I think I need to put the clip all the way at the end of the needle. Right? Midrange is retarded rich, cant get it to clean up.
  17. Ok, with no TORS its 100x better, but still seems to be RICH, so I stopped and put the needles onto the center position, they were 1 from the top of the needle, seemed to help a little with throttle response, but still seems sloppy rich in the midrange, but if you can hold full throttle long enough it will clean up.. Do I keep going up with the needle and turning in the idle mixture screws? 280 main jets, 25 the pilot jet says on it. idle screws about 1.25 out
  18. TORs removed! Seems to run a ton better, but didnt get to take it for a spin, will today.
  19. Ok, I will leave it as it is then. Thanks! I hope I can figure out how to make it run right. I noticed the pilot jet says 25 on it... I think the jet set I have coming has some bigger ones. Plugs still seem rich to me, Ill try to get a running video soon to help. Thanks a bunch.
  20. Tors removal kit should be here today, hope that helps.. Any ideas? Thoughts on the lighting coil being over limit? Could that make it have an issue?
  21. Tested these items Sent from my iPhone using Tapatalk
  22. Well, other than the white one the other stuff checks out, unfortunately Sent from my iPhone using Tapatalk
  23. Plugs from a little riding I. The field. Wet Wondering if the stator isn't giving enough spark to burn it at higher rpm. Sounds like the first run in this guys video https://youtu.be/8n0vmQzjZ1U Sent from my iPhone using Tapatalk
  24. nope, it was a bargain with an issue.
