Screamin'Sheela
Everything posted by Screamin'Sheela
Compitent Michigan Dyno's
Screamin'Sheela replied to Jereme6655's topic in General Banshee Discussion
Id be in for a dyno somewhere in SE Michigan as well -
Id go with 20 pilots, 200 mains, the hotter the better I heard.... YA
Rpm increases with choke
Screamin'Sheela replied to Screamin'Sheela's topic in Jetting & Exhaust Forum
Ok. Thanks for the info guys. -
Ohhhh. I see. Is there any way to verify its the crossover tube other than doing a leak down test? -
I did notice that those tubes are pretty old, discolored, and frail. I'll replace the old lines and see if that fixes the problem. -
I kin git'r up to 90 mph in reverse, no problem. -
Correct -
No I'm not riding with it on. Just checked it at idle. I changed my jetting recently and it is idling great, but if I pull the choke out while it is idling it idles higher than with the choke in. -
So I thought I was Lean so I switched from 27.5 pilot 280 mains to a 30 pilot and 300 mains. I put new plugs in, ran a plug chop and the plugs look perfect! But if the engine is warm and I pull the choke while it's running, it increases in rpm. Not drastically but it's noticeable. What's the issue here? I played around with the airs crew and didn't see a change.
Alright, I was able to get out to ride today finally. It seems to be running good, plugs looked ok, but there was one problem. When I let it idle without the choke it idles good, but if I pull out the choke it goes higher RPM. This means the pilot is jetted too lean, right?... I'm at 1-1/2 screws out on the air screw btw.
Ive got VF3 with a 27.5 pilot... I just changed it from 25 so I can't say definitively, but it seems to be running great so far.
I'm gonna run it this weekend and check the plugs. I'll get back to you guys.
Yeah that's what I'm afraid of... I'm going to try going up to 290 mains and bring the needle clip to 3rd. I'm not trying to blow this thing up lol
LOL this troll is creating some good entertainment for us all at least
Thanks guys! I'll try your suggestions
Yes, Very quickly. Feels too quick.
Thanks tdod, I'm going to try that this weekend. Zilla, I'm not even sure it is a problem, might just be the difference in pipes that I'm feeling. It just feel drastically different than my last bike.
Hey guys just got a 2006 banshee stock engine and carbs. Running FMF fatties, vforce 3 reeds, and k+n pods. 900ft elevation. Right now I'm at 280 mains, 27.5 pilots, and 4th clip needle. I am getting up to high rpm's very quickly on 1st, 2nd, and 3rd gear. I previously had Trinity stage 4 pipes. Am I just used to the low end power of the trinities or is this a jetting issue?
Engine is stock, but I have pipes, pods, reeds
Just bought an '06 banshee, and they came with ITP sand star 20x11-10R paddles (front and rear). Anyone have any experience with these? They any good?
CPI Inframe black vs chrome pipes
Screamin'Sheela replied to barry1me's topic in Jetting & Exhaust Forum
So you want to see a black pipe, huh?
