J-teezy
Everything posted by J-teezy
  1. What are you asking for the silencers?
  2. Yes, stingers and silencers
  3. Ideally, would like to stay under $100 more around $75 if possible.
  4. Anybody has some laying around? Pics? Cost?
  5. Not a machinist or engineer, just aware of specific technology available. Just trying to add (perceived) value to the conversation.
  6. Cfrp can be easily machined without any delamination. It just costs. It's ultrasonic technology. Mostly seen in aerospace where everyone is getting away from aluminum and going to titanium and composites. http://us.dmgmori.com/blob/269958/b23d8087fc832744d806746a7d7bcae4/pu0us-ultrasonic-pdf-data.pdf
  7. I ran into same issue but was told to go up a size on my mains. I have them ordered but haven't had a chance to try them. Currently I'm 280 mains with 27.5 pilots.
  8. Try this link! It shows the entire state. http://www.riderplanet-usa.com/atv/trails/texas_list.htm
  9. Just noticed this isn't in the correct forum spot. Sorry about that, using taptalk
  10. I recently installed v-force 4 reeds and think I need to adjust my jets. Currently have T-6, stock air box and carbs with k&n filter, tors delete. 280 main and 27.5 pilot. Pretty sure engine is all stock, but unsure because I don't want to get into it until I need to replace the top end. It ran decently prior to installing reeds. I am thinking the pilots are good but need to put 290 or 300 main. What are your thoughts? I have a modified timing plate that I plan on installing +4, but haven't done that yet. When I do, will I have to adjust jets for that as well. Any input is greatly appreciated. Thanks!
  11. Sent pm on arms and filters
  12. Also, do you have prints/design to include key hole? I want to keep my key, but adding pro taper mids won't let me keep key where it's at and not really interested in relocation.
  13. Would you be willing to make without engraving?
  14. That's what I was thinking. Thanks for the heads up!
  15. I recently installed v-force 4 reeds on my 02. When installing the very last bolt, I was tightening it up when all of a sudden it broke loose. Now I can only get the bolt so tight (just over finger tight) before it loosens up. Is it possible to just get a longer bolt 30mm or will I need to rethread the hole? Is this common? I hadn't even torqued on the bolt yet! I thinks it supposed to be around 8ft-lbs. Thanks in advance!!
  16. Pm sent Sent from my iPhone using Tapatalk
  17. Mine did the same thing when I bought it. It turned out to be the outerwear over the filter was dirty and just needed to be cleaned. Sent from my iPhone using Tapatalk
  18. What are you asking?
