Horney
Everything posted by Horney
  1. Idk what I did but it started running again. and perfect. faster than ever. last thing I had done was test the ohms and it was good. Idk. but Im so happy. thank all of y'all. I have no clue what it was. but its running. Sent from my XT901 using Tapatalk
  2. thanks for the excellent response Sent from my XT901 using Tapatalk
  3. where do I test it at? Sent from my XT901 using Tapatalk
  4. no. not yet Sent from my XT901 using Tapatalk
  5. the previous owner said it say for 2 years so he put on a new stator and it fired right up. I haven't taken the flywheel off but I did take the cover and the nut off and shined a light on it and the key looked good. I popped the exhaust off and blew threw it and it seemed good. is there a way I can test my stator before buying a new one? because this one makes great spark. Sent from my XT901 using Tapatalk
  6. I wouldn't wish whatever this issue is on my worst enemy. Sent from my XT901 using Tapatalk
  7. 93 pump gas. fresher than fresh Sent from my XT901 using Tapatalk
  8. fuel* Sent from my XT901 using Tapatalk
  9. I had my friend who's a technician on Yamaha's who has his own shop up the road stop bye and he had his hand at going through and looking at everything for a few hours. he saying it has to be in due delivery. but cant be in the carbs. and he said the reeds look good. ran leak down and compression test again. both are great. he brought a set of stock carbs that we know run. and that also didn't work Sent from my XT901 using Tapatalk
  10. I would try that but its not been hitting at all recently. youre probably gonna think this is retarded but I go frustrated and loosened the reed screws a half of a turn to where the reeds has to allow gas in. put it back together and kicked it. pulled plugs they're wet. didn't hit. but if I had it tight and put a lid of gas in each cylinder. kick it. it runs for 2 seconds before dying. makes no sence Sent from my XT901 using Tapatalk
  11. I'm really considering a 2 Into 1 setup Sent from my XT901 using Tapatalk
  12. every reed issue I've ever had involved cracked and bent reeds. these reeds look perfect. its acting like its not letting any gas in. Sent from my XT901 using Tapatalk
  13. you don't even feel the half. I've never been this defeated at any engine issue. and I'm a mechanic on Chevrolets. I wouldn't think so because when it was running it was blowing/pumping out cold air out of that side Sent from my XT901 using Tapatalk
  14. yes. it was within tolerance Sent from my XT901 using Tapatalk
  15. synced them back. still not hitting at all Sent from my XT901 using Tapatalk
  16. my carbs look out of sync. would that affect it not to run at all. not even to hit. Sent from my XT901 using Tapatalk
  17. there is no rag in it. I cannot for the life of me figure this out. and I've had every thing checked out and I and no one else can find a reasonable explanation. is it possible for reeds to look perfectly good and simply not open. the right cylinder is getting no gas whatsoever Sent from my XT901 using Tapatalk
  18. to me it seems likely reeds are not opening at all on the right cylinder. and I cant figure out why Sent from my XT901 using Tapatalk
  19. pilot jet is the one on he float? or the small one next to main. not only did these carbs come off of a running shee. but everything has been disassembled and soaked. and I have blown air and carb cleaner through every possible passageway and jet Sent from my XT901 using Tapatalk
  20. whenever I pull my carbs off and turn them sideways gas pours out of overflow. Sent from my XT901 using Tapatalk
  21. I had the cover off and the flywheel had no free play on it didn't look at the key. I had the nut off too to see of of was loose. to me it seems like the right cylinder is getting no fuel. and I know my carbs are in perfect working order. it Wil run and crank up first kick if I put some premix in the spark plug holes. for like 2 seconds. but my reeds look fine Sent from my XT901 using Tapatalk
  22. I've never had th flywheel off. it Was running right not too long ago. I dont have a flywheel puller so I haven't tried to pull it Sent from my XT901 using Tapatalk
  23. its got whitish blue spark and a strong arch Sent from my XT901 using Tapatalk
  24. the first owner said it sat for 2 years. replaced stator and put on timing plate. fired up first kick. and the spark looks great. Sent from my XT901 using Tapatalk
  25. thank you guys. I'll work on it some more asap. post what I find. I feel sorry for anyone else trying to troubleshoot this problem Sent from my XT901 using Tapatalk
