WheelieDee
Everything posted by WheelieDee
*UPDATE* banshee has bog at take off/low rpm. i filed the bosses on the carb down so i can see the idle screws raise the slides from cylinder side when disconnected from intake boot. turned my idle up high and worked on the air/screws the bike seems to have a higher rpm as i screw out the screws at 1.5 turns out and further (bog seems to not be too relevant when riding with a higher idle) then ill turn my idle back down rev it (sounds crisp) ride it still low rpm bog, and if i WOT it bogs then i have to feather tap the throttle to get around it or just clutch slip. my needle is on the 3rd clip(stock) i've ordered some 32.5pilots but im wondering if i need to go to 27.5?? my fmf pipes say use 30/260 which is whats in currently, also, my tailpipe is leaking oil one more than the other, the one leaking more oil has a darker look on the spark plug which is making me believe i am RICH?? but the low rpm bog makes me think i am LEAN smh has anybody a situation such as mine that can help me? boyesen dual stage power reeds 550ft 70-85degrees fmf exhaust/silencer k&n pods tors eliminator cross-over tube stock carbs
I filed more off idle screws, they still must be all the way in tight to run & my air screw is half turn out, this means I'm allowing as much fuel to go thru from my idle-1/8th throttle and that's the only spot where it bogs/farts, I'm thinking I need a bigger pilot? Any suggestions with ppl who have had this problem
550 ft elevation , fmf fatty, boyesen dual stage reeds, maxima 927 40:1 mix, k&n pods. 260 main/30 pilot. jus removed my tors, did the eliminator kit, and installed new dual stage reeds. ordered a 290 main since the reeds richen the main jet but the reeds lean the pilot so it kinda like bogs/farts when i give it gas starting from idle, my air screw are about 1.5 turns out and new idle screws are all the way in far as can go. im thinking its doing this from not enough gas but when i turn the screws in more the idle doesnt sound as nice and tuned as it should, and with my idle screws pulled out any it wont idle by itself without me giving it throttle.. should i go up a size in the pilot jet? P.S.also i got my throttle close to being snappy as possible if i have it with too much play the bike will just start right up bog real quick and die out, my guess is from not enough gas b/c when i rev it high it sounds good braaap but when i low rev it slightly buurps any support is appreciated, Thanks
Tors eliminated but won't start
WheelieDee replied to WheelieDee's topic in Banshee Repairs and Mods
*UPDATE* the plug was the whole reason why it wasnt sparking! plugged it back in and the banshee turned right over jus kept bogging down and dying.. what do you guys suggest on my idle tune? i run 30 pilot 260 main, fmf powercore, dual stage reeds, where should my air/fuel screw be? im so glad i figured out why the hell it wasnt running, cant believe it was that small of an unplugged cord.- 21 replies
- Banshee Tors
- wont start
(and 2 more)
Tagged with:
i unplugged this when removing my TORS for the simple reason that it wasnt hooked to nothing, can anybody tell me what plug this is? my banshee still isnt running after new spark plugs and intake boots, i know its the spark- 21 replies
- Banshee Tors
- wont start
(and 2 more)
Tagged with:
*UPDATE* same issue but i think i finally discovered the problem.. my top head must not be grounding because i have no spark while the plugs are in the head. i know this b/c i took one plug out and tested for spark off my exhaust and the bike half way started ( i heard the engine turn and rumble) the spark ran back thru to the other plug and started.. but how do i solve this problem?? when i removed my TORS i unplugged a 4wire plug that was hooked too nothing at all as well as my black box and tors cable, can anybody tell me what the 4wire plug is?? i always dont have a parking brake installation(jus sayin)- 21 replies
- Banshee Tors
- wont start
(and 2 more)
Tagged with:
it was running 260s before i installed new dual stage reeds and tors eliminator kit, i ended up having the float bowls and slides on wrong, fixed that problem but still will not start, how can you check if the fuel is getting to your cylinders?? here are my spark plugs, they still have spark, the right was jus slightly wet idk why one is darker than the other but like i said my shee was running before i tried to update it
this is what my spark plugs looks like the one on the right had a slight wetness too it.. my bike was running before these updates- 21 replies
- Banshee Tors
- wont start
(and 2 more)
Tagged with:
thanks this picture told it all i did have the bowls on wrong, but still will not start smh, what could it be slides are correct,choke tube in, how can you tell if you arent getting fuel thru to the cylinder, i replaced my stock reeds with boyesen dual stage power reeds same time i did the tors eliminator so idk if that could be the problem, carbs keep spilling fuel from overflow from not starting off my kicks&choke pulls- 21 replies
- Banshee Tors
- wont start
(and 2 more)
Tagged with:
Yea I ordered the crossover piece. Be a few days till I get that but I cleaned out carbs one at a time. How would u kno if bowls are on wrong carb mine doesn't say BB it jus says 1-1on inside of my right carb& 1-2 on the inside of my left choke carb bowl with the little needle coming out of the bowl, is that right?- 21 replies
- Banshee Tors
- wont start
(and 2 more)
Tagged with:
okay did my research and found that this is the correct way for the slides to be facing when looking from the air intake, am i right? i had the caps on the wrong carbs reversed/backwards but still no start after 15 kicks, what should i look too next? i think its just a few kicks away really ha since it was just running before tors removal.. anyways let me know, thanks for the support... p.s. the picture uploaded upside down idk why- 21 replies
- Banshee Tors
- wont start
(and 2 more)
Tagged with:
so should the slides be slightly cracked with the idle screws in?? i adjusted the slides by the caps and throttle cable then installed idle screws, dont really know how tight to have them cuz i havent been able to get the shee to start to hear the idle... this is driving me crazy i been doing all this research but no start still- 21 replies
- Banshee Tors
- wont start
(and 2 more)
Tagged with:
saint louis, Mo. stay in illinois though right across the bridge
- 6 replies
- banshee
- wont start
(and 1 more)
Tagged with:
i unplugged the brain before i even started to install eliminator, after removing brain i kicked it and it cranked after a kick or two and idled fine. i cleaned my carbs out one at a time so ik my bowls are correct slides are fine and even with throttle pull, i jus removed my reeds and checked them again seen i had a reed spacer and removed that, cuz i didnt hear too much good about those. 290main jet is on its way in the mail. im going to try again with these 260s tho.
i got two different bashees bro 96&99 #bansheeboy jus need a lil help with the mechanic and maintenace lol but yeah thats why i started two different threads
- 6 replies
- banshee
- wont start
(and 1 more)
Tagged with:
lol naw thats on my 99banshee.. this is my 96 banshee that im talking about in this post- 21 replies
- Banshee Tors
- wont start
(and 2 more)
Tagged with:
yes the black box is removed and the tors cable cords are removed. on it now boss, starting from the valve cage, i see it had reed spacers i jus removed those, gonna clean the carbs and try again.. i run 260main & 30 pilot with fmf fattys i was told to go up to 290-300- 21 replies
- Banshee Tors
- wont start
(and 2 more)
Tagged with:
Yes choke tube was connected overflow tubes as well. I'm going to order some bigger main jets and go from there, any suggestions anyone else? i got new reed gaskets in the mail as well
96 banshee, 545ft above sea, with tors, fmf fatty exhaust, kn pods, stock carbs 260 main, 30 pilot.. banshee was running fine.. removed the tors black box computer, kick started idled smooth and fine...installed tors eliminator new throttle cable tors idle screw new carb caps, and a pair of boyesen dual stage power reeds.. put the shee back together and now shee wont start can this be a jetting issue? if so what size should i run?? how tight should air screw be? help would be great, thanks
this is on my 96 banshee, stock carbs tors eliminator w/idle screws, fmf exhaust, boost bottle, kn pods, new boyesen dual stage power reeds(these reeds look different than stock its a bottom reed and top reedpedal wit a new metal reed stop correct?)- 21 replies
- Banshee Tors
- wont start
(and 2 more)
Tagged with:
okay on my 99 banshee, was running real strong till it fell over on its side on cement. continued to run strong for another 30 mins. then issues came from the exhaust it started smoking all white smoke out of one pipe only. turned it off and parked it. took the spark plugs out checked them, looked fine. problem is the banshee will not start back up so i can't really diagnose the problem. does anybody know where this could come from?
- 6 replies
- banshee
- wont start
(and 1 more)
Tagged with:
okay so i started my banshee the day before ran in idle smooth. next day i installed my eliminator kit & my boyesen dual power reeds on my stock reed cage. i followed all the proper instructions, filed down the left&right carb outside for my new idle screw.. even removed the black tors computer on the frame the day before i completely removed my tors and like i said my banshee ran smooth during idle. took off the tors cable that runs from the throttle, sealed it, unplugged all the extra cables. synced the carbs the slides are equal. put my k&n pods on and tried to kick start it, no start.. i thought it could be the reeds so i took them out and loosened the screws so the pedals could be a little more looser still no start. can somebody help me find the problem? 565ft above water, and i ride on the streets(outlaw)
- 21 replies
- Banshee Tors
- wont start
(and 2 more)
Tagged with:
