dttuner
Everything posted by dttuner
  1. Is this good, bad, normal? I do a good bit of wrenching on my own cars, and coolant dropping 30% after 3 hours is BAAAAD medicine.
  2. What would this look like? Do I have to do the "run it hard through all 6 gears, then kill engine" routine? Problem is, where I store the banshee, I can't run it on the street. Will get arrested in 3.47 seconds. I'd have to trailer it somewhere safe to ride, and do all my testing there.
  3. Northern NJ, near Paramus. I can come down during the weekend. I'm hoping to make a run to the Pine Barrens some day soon. Never been, but always wanted to ride the sand dunes.
  4. That was my kind-next thought. But since it requires draining coolant, I was trying for any external/superficial troubleshooting first. Already have a spare water pump gasket, and EngineIce coolant is on the way. Might have to bite the bullet, buy a metal impeller, and check the pump (and replace it while I'm there regardless).
  5. Howdy BansheeHQ. Long-time lurker, first-time poster. I used to own a '96 Banshee, which I loved for several years. Sold due to finances, and regretted ever since. So few weeks ago I finally put enough cash together to buy myself another banshee. Anyway, I think I may have a coolant-related issue. Took her out for the first time, after changing trans oil, topping-off coolant ("Full" line in reservoir, and checked rad), lubed chain, cleaned and oiled air filter, and synced carbs (mechanic did that for me). 2004 LE, 99% stock. Pro-line air filter with stock airbox, reservoir in place. After about 20 minutes of light-medium riding on a 85 degree day, I noticed something spitting out and dribbling onto my front headers. Could not see where it was coming from, although I noticed the tube coming out of the gas cap looked wet. After riding for about 2.5-3 hours, I packed it up and went home. As I secured the banshee to my trailer, I noticed the reservoir coolant level had dropped from right at the "Full" line, to about 1/3 the way down to "Low" line. So, naturally I started browsing the bansheehq forums for an answer. Here's what I found, and checked so far: - Opened Rad cap, kicked motor. Didn't spit out coolant, or notice any bubbles. - Head bolts are tight - No obvious wetness, or leaking from the head gasket (visual inspection only) - Started, and Ran the banshee for 15 minutes. Revving to mid-throttle, etc. Radiator got hot enough to smoke the remaining moisture off, from when I washed the quad earlier. No LEaks... - Squeezed coolant hoses, and tightened hose clamps, to check for cracks, etc. I did notice and identify a header-to-engine exhaust leak. Already ordered FMF o-ring and spring kit. Any suggestions? Anyone live in the NY/NJ area, who would be willing to help me out? Thanks!
  6. Evening, banshee hq
