gregckrt1
Everything posted by gregckrt1
Can cylinder stud stretch? Also what should I look for after I get done rebuilding the top end ? Sent from my iPhone using Tapatalk
Ok I'm getting new cylinders since my other stud bolts stripped them out. Trust me went threw everything to try n make it work but anyways would I be able to use my old studs or no bc they're stretched one dude told me I couldn't bc they're stretched so I figured I'd ask Sent from my iPhone using Tapatalk
I have stock mikuni carbs chokes only on one side Sent from my iPhone using Tapatalk
Problems with right cylinder firing
gregckrt1 replied to gregckrt1's topic in Banshee Repairs and Mods
It feels like I have good compression in both put my finger over just a quick test till my buddy comes over with compression tester Sent from my iPhone using Tapatalk -
Just recently rebuilt my 03 banshee didn't even get to ride it and only one cylinder is firing it did alittle when I first started it but now it's blowing cold air switched the plugs and wires still happens thought a fire was grounded out nope still happens. Could it be I have a leak in my gasket when it gets hot?? If not what could it be ??and if it is how could I fix it I torched them down and have permatex ultra copper on the seal on it does it mean I have to get new seals ?? Sorry for all the questions just want to get out and rip the coal hills Sent from my iPhone using Tapatalk
Switched the plugs to. I thought a wire was grounding off of something bc there was a few open wires but nope it started to get alittle smoke and then went away Sent from my iPhone using Tapatalk
Yeah and it still happens to the right one Sent from my iPhone using Tapatalk
I rebuilt my banshee put everything back together correctly and both cylinders have compression but it want fire on right side left side blowing hot hot exhaust and right cold n no smoke I cleaned the carbs and the fly wheel. What could be some other possibilities it could be Sent from my iPhone using Tapatalk
I'll post pics later today I'm at work and and thank you everyone for your help and I'll start pricing cylinders and see if I can save myself Sent from my iPhone using Tapatalk
I mean it's like 5 bucks for 10 and I mean I could take it to a machine shop but like the other guy said it will cost a lot of money so I'm wondering if buying a blown banshee for 800 is the best bet Sent from my iPhone using Tapatalk
Ok well I thank you for your honesty and I'm looking into getting a stock blown shee and using the parts from that and @special07shee I stripped them out of the case Sent from my iPhone using Tapatalk
I was went 10 at a time idk I never used a torch wrench before and that what someone told me that was there who built there's before not saying I'm not wrong bc I probably am but any will the heli could work if I put them in @GRAVEL ? And I was tryin to do it in increments like 10, 15, then last 20 Sent from my iPhone using Tapatalk
So I when I was rebuilding my banshee everything went together all nice except when I had to put the head back on the cylinder and 4-5 of the studs stripped out and I replaced one with a heli coil and then they all just started stripping out I think it was bc of my torque wrench but I didn't know till the weren't tightening idk what to do should I just heli coil them all and put alittle high temp lock tight on it or if I fucked my whole motor please help. Sent from my iPhone using Tapatalk
Looking for stock cylinders or after market let me know what you have Sent from my iPhone using Tapatalk
I stripped out the stripped out the cylinder hole that the stud goes into idk how I did it but I did. Should I get a bigger stud for it or should a heli coil or time sert work just fine Sent from my iPhone using Tapatalk
Ok man thanks Sent from my iPhone using Tapatalk
What's a fairly reasonable priced chain that's good? I know you get what you pay for but I haven't been riding in months and I've been itching to go lol Sent from my iPhone using Tapatalk
So I'm getting her rebuilt and she will be done this week but my chain is stretched and I want to go to a poker run this weekend is it safe to just take links outve the chain or should I just get a whole new chain? Just asking bc I'm tight in cash after I gotta pay for the rebuild Sent from my iPhone using Tapatalk
I need to do a rebuild and I was wondering what piston would be better a weisco or a pro x ?? Or if there are any others that are good and reasonably priced open to suggestions Sent from my iPhone using Tapatalk
Hahah ok how about fairly good? Sent from my iPhone using Tapatalk
What's the best brake/clutch lever for a reasonable price ? Sent from my iPhone using Tapatalk
Ok I'll check all it tonight and let yahs know how it went thank you Sent from my iPhone using Tapatalk
Carb slides are in right I checked them before I put on the air box the needle is down in the hole and the slides are synced Sent from my iPhone using Tapatalk
What is a leak down test ? And i will do a compression test today. I have full fmf pipes other than that I don't have any other mods the spark is really good it's gapped at 18 Sent from my iPhone using Tapatalk
I recently took off the carbs to clean them and it was alittle hard to start before but did not backfire. I put a 280 main and a 27.5 pilot jet in it and now she hardly starts might after 70 kicks. And backfires like a mother. My spark plugs are gapped right. The carbs are synced. Maybe it's getting to much gas? Or are the reeds not sealed right? Any tips will help please Sent from my iPhone using Tapatalk
