gregckrt1
Everything posted by gregckrt1
  1. Ok I'll let u know how it goes. Just a leak down tester right ? I don't really want to take it to the shop I rather learn how to work on the machine by myself but if I have to I will yah know Sent from my LG-H900 using Tapatalk
  2. How do u test the cooling system ? Sent from my LG-H900 using Tapatalk
  3. How would you know if head is warped Sent from my LG-H900 using Tapatalk
  4. Yeah I followed the torque sequence 10.15 20 and the top head gasket was new when I put it on today. Also I reused the bottom ones bc I had to get cylinders hoaned but last year I only road a little but like 20 mins half hour before I noticed leak coming from head gasket so I figured the bottom gaskets would be fine ?? Sent from my LG-H900 using Tapatalk
  5. Oh yes I also had my cylinders honed today bc of a little rust the local shop did it for me Sent from my LG-H900 using Tapatalk
  6. Sent from my LG-H900 using Tapatalk
  7. Just a stock head Sent from my LG-H900 using Tapatalk
  8. Sorry it's been so long since I last posted. I had some legal issues but anyways. I rebuilt my banshee literally today and torqued everything to spec put the pipes on clean the carbs I got stock cylinders and pistons so the carb idle and air screw should be the same right??. But here the problem I'll pull out the choke all the way and it will start and it has trouble idling and when I hit the gas it will go for a little and stall out. Then when I try to start it again it will back fire. It kinda sounds like both pistons will fire on n off but at separate times. The pipes are blowing hoot white smoke also please anyone that can help I'm open to advice and I will message back now bc I will have phone on me at all times Sent from my LG-H900 using Tapatalk
  9. Also what do the studs need to torqued down to ? Sent from my LG-H900 using Tapatalk
  10. Does it matter what kind of gaskets you get ? Namura? Athena? Sent from my LG-H900 using Tapatalk
  11. Oh ok well thank you Sent from my LG-H900 using Tapatalk
  12. Do you think I was looking compression from the leak and can get new gaskets and torque everything down to the spec? I mean do u think it's a possibility ? The cylinders and head look clean no scrapes, dents or dings Sent from my LG-H900 using Tapatalk
  13. Yeah I hear the snap-on ones work great. N ur right I should have just gotten a better one but I figured hell what's 15 bucks Sent from my LG-H900 using Tapatalk
  14. Harbor n freight
  15. Also it was under a patio with a tarp on. Not was protected from the snow and rain Sent from my LG-H900 using Tapatalk
  16. They didn't do the top end they were suppose to look over everything and I called the day after and they said they can't ride it they can only start it up for a couple mins and that's when I hung up the phone lol Sent from my LG-H900 using Tapatalk
  17. Yeah I know I kinda just had to get away from it and ok I'll try when I get off work I'll let u know Sent from my LG-H900 using Tapatalk
  18. Last fall I have gotten my shee back from the shop from a fixed stator and a couple miscellaneous things. Fresh rebuild And when I got home I figured I could go ride it so I get about 15-25 mins in and it starts leaking coolant out the over flow and then from the head. I let it sit all winter and have it a compression test yesterday it ran right up to 60 and stopped both sides could this be from the leak? Or could it be that I blew it up when riding it that 20 mins ? Sent from my LG-H900 using Tapatalk
  19. Defiantly clean the carbs and make sure they're synced also what hoppedupandcutdown said use fresh gas Sent from my LG-H900 using Tapatalk
  20. Ok I'll check compression tomorrow u would think it had compression since it's a new rebuild right ? And it blows more cold air when rev it up. I'll let u know what's up. Btw thank you for helping me Sent from my iPhone using Tapatalk
  21. I switched the plugs fired left side switched the plugs fired left side but didn't fire right any of the times. its getting gas to both carbs verified. I just rebuilt it Sent from my iPhone using Tapatalk
  22. Yes I have Sent from my iPhone using Tapatalk
  23. Machinegunbanshee yeah exactly Sent from my iPhone using Tapatalk
  24. Rebuilt Top end the right side is not firing up switch the plugs the plug wires and still right side carbs can be clean as can be flywheel clean as can be tried literally everything besides switching the carbs. And getting longer choke tube but my right cylinder should still be firing up even if it's the carbs right? But anyways please any information will be helpful Sent from my iPhone using Tapatalk
  25. Ok thank you guys ! Sent from my iPhone using Tapatalk
