jeff n
Everything posted by jeff n
  1. Sorry, wrong screenshot. Sent from my LG-H811 using Tapatalk
  2. Sent from my LG-H811 using Tapatalk
  3. Not sure exactly where this should be posted, just trying to pass along someone else's add and everybody hates a thief. Sent from my LG-H811 using Tapatalk
  4. Thanks Sent from my LG-H811 using Tapatalk
  5. Is he a member here? If so what's his profile name? Sent from my LG-H811 using Tapatalk
  6. Has anyone ever ran or heard about mull engineering quik shift kit. It says by electronically interrupting the engine power you can shift with out using the clutch or letting off the throttle and will not cause any damage to motor or tranny. Sent from my LG-H811 using Tapatalk
  7. Camatv built my motor and did pro mod trans. He did a GREAT JOB! I ride with a couple of guys with most of the same mods as me plus more(both should probably beat me) but built by other builders and the best they can say is " you didnt beat me, I was right behind you". Sent from my LG-H811 using Tapatalk
  8. jeff n
    Halftime show
    It is black history month, maybe people should study the history of the black panthers, what race bought and sold more slaves than any other or what race(and religion) STILL enslave black people today in different parts of the world. Sent from my LG-H811 using Tapatalk
  9. Sorry, just seen that your in Salem Sent from my LG-H811 using Tapatalk
  10. Liquor store opens at 9:00, can have your beer to you by 9:30 if you're in the area Sent from my LG-H811 using Tapatalk
  11. If you still have them, i would love to bring you some beer. Im in Wichita ks Sent from my LG-H811 using Tapatalk
  12. jeff n
    Halftime show
    Does anyone else think the halftime show was a gay pride festival that rounded itself out with black panther rally? Sent from my LG-H811 using Tapatalk
  13. An empty can rattles the most Sent from my VS985 4G using Tapatalk
  14. Dude! If you have that much squish out, then that much squished in. Even when cured for 24 hrs you don't want that in your motor. And I'm pretty sure that this is the first time I have ever seen someone put sealant on seals like that. Sent from my VS985 4G using Tapatalk
  15. He's had that thing on there for a while. I think he was asking $400 for it when he first posted. He had another junk Shee on cl he was trying to get do top $ for. Sent from my VS985 4G using Tapatalk
  16. Pics are of my buddies motor that jsr sent out as finished product after a $2800 complete build. My conclusion, no pressure tests on mine or his. I'm sure John thinks that all leaks should just seal themselves out of gear alone. Sent from my VS985 4G using Tapatalk
  17. It's possible that the crank seal went out after I picked it up but after seeing pics of a complete build that he did leaking from the head and boost bottle, I'm guessing the bad crank seal probably was the cause of my original problem. Sent from my VS985 4G using Tapatalk
  18. I forgot to mention that it took him 6 weeks to diagnose(pulled head and seen busted piston ring) , port and reassemble top end. Sent from my VS985 4G using Tapatalk
  19. Had him build that motor and burned it up during break in. John told me that I must have rode it too hard, I took to camatv and had him check it out. Bad crank seal. Jsr doesn't pressure test anything. If you're in the Wichita area, do you know if any good places to ride other than badlands and LS? Sent from my VS985 4G using Tapatalk
  20. Did you ever have jsr do any work for you? Sent from my VS985 4G using Tapatalk
  21. There's no substitute for a leak down tests Sent from my VS985 4G using Tapatalk
  22. This was a brand new top end done by jsr(the guy that's so good that leak down tests aren't necessary) a pressure test before tare down or after assembly would have save a lot of time, trouble, and money. Now I'm having cam build it again. Sent from my VS985 4G using Tapatalk
  23. If you run 4, do 2 of them have to be upside down? Sent from my VS985 4G using Tapatalk
