TurnerBanshee
Everything posted by TurnerBanshee
  1. Yes, the stock silencers will fit on your pipes, but I think that they will not sounds good this combination, but for your case will work
  2. Yes, every time without use the choke
  3. a friend said me that if my banshee everyday starts at first kick without use choke the carbs are bad, true or false? NOTE: my banshee sometimes starts at first kick using the choke, sometimes not!
  4. Need one perfectly straight, not bent please
  5. Hi, you still have a dogbones? I need one but the best that you can have good bushing and stock color or similar
  6. Not boy, good very very very premix
  7. Not problem but for save your life in a emergency is great!!!
  8. When I bought a engine comes with radiator and also comes with this but I don't know if those piece work for sure
  9. actually I use 15/41, but for do wheelies is very faster and I need some slow, for the moment for learning
  10. so if I need to put a battery for led flickers reason, the installation change, where wires put the battery?
  11. you can show which small battery could be please?
  12. Got it, 1- works led with rectifer and stock stator? 2- if I put 2 round or square leds in stock location I need 2 rectifers? Or just one?
  13. Where install this? Or how to install? I think that I take the yellow wire and put in a source that in the momment I turn on the shee send current? Ground any part of frame and red and black in the LED light? http://www.ebay.com/itm/Universal-Snowmobile-Rectifier-Converts-12V-AC-to-12V-DC-Voltage-ATV-/171266352572?hash=item27e04525bc&vxp=mtr&rmvSB=true
  14. I would like use a more power light than stock yellow halogen without use a battery, I could buy 100W or 200W stator for use the stock headlight and 2 more lights like PIAA 005 xtream white or trailtech mr16 for help the stock lights I try iluminated a little more than only stock What stator watts is would works good for 4 halogen light all 35/35 watts because I try to search 40/40watts or 55/55 watts and I can't find this watts in this halogen system
  15. Well, tell me which is better if you have both headlight, which illuminates more in your experience?
  16. But you have all right, is better buy a new crank that rebuild, I saw the prices between rebuilt(bearings, hot rods connecting, pay for mount all that in the crank) and New SAME PRICE thanks
  17. I have two cranks, actually one work on my banshee and other that is bad (cause by blow up) this crank has one connecting rod good the other not, if I repair this I suppose that recommend is change both connecting rods, I don't know if change only external main bearings or all set main bearing of the crank, I don't planning buy a brand new.
  18. I planning rebuilt my engine with good piece but the first problem that I have is, I don't know what is way better choice, buy used crankshaft? or rebuilt my crankshaft put new bearings and connecting rods?
  19. anyone has one pair in good condition, not broken!
  20. anyone that not need or has a complete kit for remove tors
  21. Is a little joke I from colorado, thanks for the info now this is my FAQ
