timothy kaim
Everything posted by timothy kaim
  1. It didn't really start it tried to, and when I ride it the clutch felt a bit weak, but didn't even ride it much being that the carb was leaking
  2. Yes sir I just hope nothing else went wrong in the process, thanks for all the input!!!
  3. The basket and everything is waisted
  4. Yes he did
  5. Well here it is guy I bought it from said he just replaced the clutch plates and put hd springs haven't even rode this thing since I bought it.what would make this happen? just got done rebuilding it.
  6. Ya that's what I ment to say if I move it by hand like back and forth it will go down but that's just gradually? Hopefully the spring is off
  7. Pulled the plugs and nothing, guess I'll pull the stator cover and hope the spring is stuck or some shitttttttt
  8. Very good point.thanks
  9. Thanks a lot! For the help. hopefully it's full it's too late tonight I will check it after work tomorrow and let you know, don't want to sound stupid but if it's full with fuel then it's not the cylinder right?
  10. Wow not what I needed, so if I pull the plugs and it kicks then it's prob the cylinder?
  11. I will pull the plugs, sorry I'm new to this two stroke world, the left side carb was pouring gas out of the left float tube I thought maybe it would clear out so when I didn't ride it I would turn the fuel off, when I got it in the woods and it stalled or shut it off I had to kick the shit out of it to get it to start, that's why I'm wondering if I may have worn out the kick starter?
  12. The gas was off for a couple hrs turned out off after riding it.I will take the plugs out and see if it kicks, if it kicks with the plugs out in screwed? Or could the kick starter assy be bad?
  13. It was leaking gas out of the over flow on the left side
  14. Broke what the kick starter?
  15. Rode the bike this weekend and it kick started fine got it home and tried to start it and it tried to start bogged out then tried to start it again and the kick starter won't move! Any suggestions Thanks
  16. I did, it was fine till I let it run out of gas?I will definitely test them down I've went this far might as we ll rebuild them, thanks for all the help!
  17. Thanks I will try when I get off work I'll let Ya know what happens
  18. Ok I'm going to ride it this weekend and hopefully it frees up if not I guess I'll rebuild those too
  19. K that's what I figured I also let it run out of gas don't know if that may affect anything Thank u
  20. Hello I have a03 banshee it just started leaking gas out of the left side carb it didn't do it before I haven't rode it since I tore the bike down and rebuilt I haven't touched the motor, so do u think if I ride it will it free up the float?
