timothy kaim
Everything posted by timothy kaim
  1. Yes sir thanks tricked!!i woulda never known to check this.
  2. Alright new squash results with head torqued down
  3. I just have the o rings on the cool head And a cosmetic under the cylinders.the head isn't torqued it's just snug
  4. Ok this is what I've come up with i did it 4 times left side was.87 right is.90
  5. U think they are cut correct being that they are scribed
  6. They are scribed 23mm 4mill on the side of the dome.
  7. Ok i gotcha i will have to get a measuring mic tho measure the flux.if there isn't enough clearance if i have 23mm domes should i go to 24s
  8. Thank u very much for your help!i will give it a try later off tomorrow.so just measure the squash of the fluxafter the squash?
  9. How do i do a Squash test?the motor has a h.r 4mill stroker crank and wiseco .40 over pistons 795m06500 and when i look up the piston it says long rod.thanks for the help!!
  10. Do i use the metal gasket between the cylinders and coolhead
  11. Where do they go under the head gasket above it?and also out did have a metal head gasket on it When i took out apart Just don't remember Where the orings go.it's has a 4mill stroker crank and wiseco .40 pistons 795s
  12. Hello is their a write up on how to install a cascade pancake bearing?.thanks
  13. I don't know yet I just built the motor going to set at 0 for now .30 over h.r 4 mill stroke crank.I will prob go to+4
  14. Hey also on the cascade timing plate it only can with three hex head bolts with no washers factory had washers is our necessary tho put them on?
  15. How do uadj the pick up gap of it was off I don't anywhere to adjust it.
