naoh05
Everything posted by naoh05
  1. I run Redline Racing oil at 32:1 so it's up to you Sent from my iPhone using Tapatalk
  2. If ur fuel is mixed 32:1 then go 230 on the mains or if ur at 40:1 for fuel I would go 220 on the mains once u choose ur main jet based on your fuel mixture I would adjust the air screw starting from about 1.5 turns out from all the way in... If it still bogs let us know! Sent from my iPad using Tapatalk
  3. Go up to 210 or 220 on the main... I would start at 220 and the air screw should be about 1.5 turns out from all the way in Sent from my iPad using Tapatalk
  4. What are you mixing your fuel at? Sent from my iPad using Tapatalk
  5. Also what is the outside temp and humidity level, also fuel mixture? Sent from my iPad using Tapatalk
  6. What kind of filter? Sent from my iPad using Tapatalk
  7. 14mm I believe Sent from my iPad using Tapatalk
  8. Sounds like a plan! Sent from my iPhone using Tapatalk
  9. Air screw should be about 1.5 turns out... What elevation are you at? Sent from my iPad using Tapatalk
  10. Are they as good as GT Stators from Gary? Sent from my iPhone using Tapatalk
  11. What is this stator for? Strictly ignition? Sent from my iPad using Tapatalk
  12. Really only mods that I know of are Wiseco pistons rods/crank, T5 exhaust, port/polish, and I believe the cylinders were resleeved by LA-Sleeve. Elevation is 890 to 1530 ft. 32:1 fuel mixture Sent from my iPad using Tapatalk
  13. So it's luck of the draw to get ones that fit properly? Sent from my iPad using Tapatalk
  14. what do you mean by tolerances?
  15. i've read some people didnt have good fitment with them on here. i wonder if they got warped or something.
  16. The Clymer links are not working
  17. why not just race cut the fenders?
  18. When I bought my banshee back in 2007, T5's were already on there. Toomey's website suggests using their perfect jetting kit with the pipes, but when I pull the carbs apart, what sizes are the perfect jets? if the jets are stock sizes than i know the kit wasn't installed, so what are stock sizes? Any help would be greatly appreciated!
  19. No not even a welder, but we'll see some day lol. Sent from my iPad using Tapatalk
  20. Jja have the carrier clamps is that to make ur own swing arm? Sent from my iPad using Tapatalk
  21. Stock sing arm and axle yes Sent from my iPad using Tapatalk
  22. What about the swing arm since I didn't see any on their site? Sent from my iPad using Tapatalk
  23. Lol I just might! Sent from my iPad using Tapatalk
  24. its mainly set up for sand... dune hillshots and cruising around the dunes
  25. whats great about being gundrilled? and why are the lengths different?
