1999shee
Everything posted by 1999shee
  1. also depends on your elevation
  2. 27.5 pilot, 270 main , needle third clip , air idle 1.5 out ( and adjust ) tors delete ?
  3. Im starting to think I have the wrong slide in the wrong carb......I thought they were both the same ? and the same bowl came off and went on the same carb so cant be that
  4. Hey Guys need some help , - 1999 shee with stock box and fmf exhaust system , had an idle issue so I Upped my pilot to a 27.5 from a 25, mains are 270's, now as soon as I start it it revs to the moon !, carbs are syncd no air leaks , could a slide be in wrong? float stuck ? (has tors eliminated) cables are not pulled out of the caps and the slides are touching the bottom of the carbs .... thoughts ????
  5. Okay guys so changed the pilots to 27.5's and now as soon as I start it it revs through the moon ! Thoughts ? Cant find any air leaks , could a slide be in wrong ? float stuck ? the checked the top of the caps too...cables are not stuck , slides are all the way down.. spent two hours trying to figure it out. Any ideas greatly appreciated
  6. Thanks for your help guys
  7. all that stuff is good to go, Ill try a 27.5 pilot with air screws at 1.5
  8. Ill give that a try , what are u thinking a 27.5 or a 30 ?
  9. Hey Guys , new to this site and just looking for some jetting expertise. I have a 1999 banshee stock air box with FMF Powercore II exhaust, K&N filter, no other real mods motor was a fresh rebuild last year. Ive been messing around trying to get it bang on but haven't hit it yet. Its idling very low when warmed up and will die out if I let it sit, just changed to a 270 main, pilot is 25 ( I think too small ?) air screws 2 out clip mid position. it has a bog at low idle 0-1000 rpm ...pilot too small ? any help appreciated, elevation roughly 1000
