yamaha_4_life
Everything posted by yamaha_4_life
  1. Check float height.
  2. New voltage regulator fixed the issue..
  3. Oh I'm sure you're right about that.. I'd like to remove them eventually but for now I think I'll just unplug them.
  4. And it's the black box that's up under the radiator area correct. ?
  5. Will it affect anything if I unplug it.. like the way it runs or anything. ?
  6. What the benefits in deleting them.. I mean what do I gain by unplugging them cause they don't seem to be a problem..
  7. OK. Just let me know. If you do what would you want for it. ?
  8. How do I delete the tors system on my banshee, will unplugging it be okay or do I need to do something else.? I read something online that said I can just unplug it and leave it unplugged..
  9. That's what I'm assuming I need. It keeps blowing headlight bulbs..
  10. Do you have a voltage regulator ?
  11. Any of you guys still wanting to sell some pipes let me know. I looking at buying some here pretty quickly..
  12. Would you just sell the lights ?
  13. ^^^^ Yeah I'm curious also.
  14. What's the bottom dollar you will take for the pipes ?
  15. But wouldn't you think if it is the voltage regulator that went bad that it would have popped the tail light also not just the headlights. ? Sent from my SCH-R950 using Tapatalk 2
  16. Yeah I touched them with my hands.. But I also handled the tail light bulb which is still working great. So my next question is where is the voltage regulator located at and how can I check it to see if it's bad or not.? Sent from my SCH-R950 using Tapatalk 2
  17. Just picked up a banshee and the headlights and tail light bulbs was burnt out so I went and got new ones but the headlight bulbs that I picked up were 25w instead of the 30w which came out of it. Installed the 25w bulbs anyways and correct tail light bulb. Started the bike and all lights worked fine for a second then both headlight popped but the tail light stayed good.. so my question is did they pop cause they weren't the right bulb or did they pop cause my voltage regulator is bad..? If its cause the voltage regulator then shouldn't it have popped my tail light also.? Please help Sent from my SCH-R950 using Tapatalk 2
