I have no spark but every now and then I will get a spark here's a list of what I've check.
I used the following website for help:
Banshee Electrical FAQ - DFN Systems
www.dfn.com/agservices/elecfaq.html
Kill switch test good
Key switch test good
Stator coil: red to green 19.8 ohms
Pick coil: red/white to green/white 112 ohms
Lighting coil: yellow to black 0.5-0.6 ohms
Ignition coil test:I have two coils, one is new aftermarket and other is old oem
Primary test: 0.6 ohms old and 1.0 ohms new
Secondary test: wire with and without caps 5,700 ohms old and 6,000 ohms new
Torrs was eliminated before electrical problem
I also ordered some new spark plug caps and they tested out at 16,000 ohms on both coils NGK caps. When I put the new ngk plugs it fired and ran for couple minutes then lost spark and died. Couldn't get spark again so I thought maybe my ignition coils was bad so I ordered new one put that thing in and got spark for a second then went out. I'm down to the wiring harness the grounds or the CDI box. I read somewhere that the CDI box either works or doesn't work it doesn't just sometimes send a spark and sometimes it doesn't is that true or not? How do I check my ground wire going to ignition coil? Appreciate any help or suggestions at this point. Not sure if I should order cdi or wiring harness?
