maxpower49
Everything posted by maxpower49
  1. In New York the registration is proof of ownership, so if you buy a quad it should have a transferable registration and as soon as you transfer it to your name that is your title/registration. Also all atv registration expires on august 31st so everyone has to renew, not sure if the price is by county or just the same state wide but where I am in the state it is usually a flat rate of $12.50 per quad for a year.
  2. I am using a front caliper as my rear brake, it looks much cleaner in my opinion and I had a custom brake line made with a 90 degree elbow in it so the stock line wasn't a tangled mess in the rear. One thing to note is if you use a front caliper on the rear you have to use the slide pins from the front caliper but you have to use the base mounting plate from the rear caliper. It bolts to the pins of a front caliper but it allows it to actually fit the stock rear caliper mount otherwise it would be too narrow. Oh and you either have to bleed it off of the quad with an old rotor wedged between the pads or I just used a vacuum bleeder and it worked like a charm and didn't have to mess with removing it.
  3. I kinda figured it would be decent it seems every arm unless it is a heavy mx arm only has the two bolts, plus this is just going to be an overpowered trail bike any way so no massive jumps or things of that nature. I have though about welding on a couple more pinch bolts towards the center I have a fairly nice mig welder that would do the job but I am not sure I want to mess up my powder any further for the time being. I know I should have checked before powder but I didn't have the carrier at the time and I never though it was going to be too small... Oh well live and learn if I need more support I will cross that bridge later or just pick up a new one. Thanks for the tip as well I will measure it up next time I am out in the shed and see what everything measures before going any farther with this arm.
  4. Well my new to me carrier showed up and it was still too big to fit so I ran to the local machine shop and unfortunately the snap ring groove and where the bearing race goes are extremely close to the edge and after some measuring it would have to be cut down extremely close to where the bearing rides so the carrier can not be cut down safely to fit the swing arm... So after getting fed up enough I just chucked the arm in the vice and slit the thing down the middle with my sawzall and spread the damn thing open and slipped the carrier in. Hey it finally fits and every single arm I have seen is already cut down the center so hopefully I didn't kill the strength however if every one built today is already split I'm not entirely sure how much different things are. Once I finally have the bike assembled and ruining I will take it extremely easy on it and if all feels well I will run it for a season or two before changing it up to a brand new arm, if it feels sketchy or unsafe I'll just bite the bullet and buy a swing arm.
  5. I bough a coil from him and it showed up quickly and was exactly as he said it would be, it was a quick simple transaction all in all.
  6. I have no idea as to the brand of the arm but I am fairly sure it is not a leager arm, if it is I got one hell of a deal haha there was a small amount of powder in the arm and I went at it the other day with a dremmel and wire brush and removing the powder had no real effect unfortunately. It is an anodized carrier in black however I do not see anything on it that would prevent me from sliding it in. I did pry it open quite wide and in the last picture the left tab is still kinda sprung open but I had it spread wider than that with my brother trying to get the carrier in and it still would not slip past it is about 2mm too small from everywhere I have measured which doesn't seem like much but it is a major pain in the ass when trying to slide a carrier in. Any way as a bit of a minor update I won an eBay auction for a RAD carrier and here is hoping it is just a tiny bit smaller but if not it was inexpensive enough that I won't feel bad getting it turned down at the local machine shop I do not like the idea of cutting up my nice new JJ&A carrier for a cheap swing arm. I will update when everything shows up just for giggles and to help anyone that happens across this post in five years after I sold the swing-arm and the carrier gets separated haha.
  7. I picked up a used round house style swing arm for my banshee and figured they were all pretty much one standard size for the carrier, I powdered the arm and picked up a refurbished JJ&A carrier and after attempting to install it in my arm it is just plain not going to fit, I measured the arm and pretty much wherever I measure I only get a maximum of 85 ish mm and from all of the digging I have been doing trying to figure out why it will not fit I have found out that banshee round house carrier are about 87mm, so I measure my JJ&A carrier to make sure it is the correct size and it is a 87mm carrier. After a ton of searching I am getting tired enough of it to finally start a post on here asking for help... From a bit of the searching I have been doing I think the back half is a Honda design it is one solid piece kinda like the 250r swing arms but I can not for the life of me find a specific size for the Honda round house carrier so I was hoping that someone on here had a general idea on the size of Honda carriers, and if it is the right size I will just pick up a Honda carrier. And before you ask the round tube the carrier slides threw is one solid piece and I cannot just pry it open and slide my JJ&A in, I tossed in a couple pictures just for giggles to show what it looks like, and if any one has any idea towards what brand the arm is it would be nice to know. Also from my searching it seems that Honda uses 40mm axles so if I bought a Honda carrier could I just buy the 35mm banshee style bearing kit and swap them out or would the od of the entire bearing be different?
  8. Shipped everything out quickly and it was still in factory original packing so no issues there, had a slight issue with alba sending the wrong ball joints but he took care of everything with alba and even shipped me the correct parts once he got them. Great seller and he was going to make sure everything ended up alright even if it meant him buying the correct ball joints, however alba did ship the correct ball joints at no cost, even though they took a while everything ended up alright.
  9. He has the bumper up on eBay for $149 plus shipping, the battery, regulator/rectifier and mount is on Facebook and it is $170 for everything the battery, 200w regulator/rectifier and gas tank style mount.
  10. He shipped everything out quickly and was quite quick with any and all communication.
  11. Haha I was bidding on these things as well
  12. My bad I guess, I just saw that it was in boxes and only saw the steering stem and did not see the a arms were also roll design
  13. http://buffalo.craigslist.org/snw/5167734805.html Deal of a lifetime here! I have no idea where people get their prices around here...
  14. http://fingerlakes.craigslist.org/mcy/5148686731.html Every time I search for banshee stuff on craigslist this thing keeps popping up...
  15. I figured as much but he is still might want to clean out his inbox for future sales
  16. I tried to send a message about the alba arms but it says you are unable to receive any more messages.
  17. Got the shipping quote quick and shipped out just as fast.
  18. I'm about an hour and a half south of Buffalo and 90% of the snow is gone just been replaced with mud everywhere, all I need to do now is piece together my banshee...
  19. That's a different kind of leak down tester, it only really tests the top end, on four strokes it can help find burnt valves but on a two stroke it is only really a glorified compression tester and I suppose it could find a bad head gasket as well but it runs off of an air compressor and it only fills the cylinder with air not the entire engine. The one that everyone talks about on here fills the whole engine with compressed air from a bike pump and there is a sticky at the top of the technical info section of the forum on how to build one and use it and here is a link to make life easier click this.
  20. Shipped quickly and I didn't have any issues what more is there to say
      • 1
      • Like
  21. Picked up one of JD's reaper coated radiator covers for my project and this things looks awesome! I wish my camera took better pictures but this thing has a nice polish to it. Over all the thing looks awesome and even though I did not send one of my parts to him I'm sure it would have had similar results if I sent my own in and JD was an easy guy to deal with and lives up to all of his other reviews on here. All I need now is a custom grille ​ .... and a running quad
  22. When I rebuilt my carbs a few months ago the rebuild kit I bought had the new tubes with the kit, along with the needle and the rest of the parts to rebuild the carb, and from looking around online most kits seem to come with the tube, so if you have or ordered a rebuild kit you should be getting new ones with the O-ring that goes with it.
