Thomas_S
Everything posted by Thomas_S
  1. I'm asking 2600 for mine but I'm located in Michigan. Mines pretty much stock excepts its bored and has a cool head w/ 21cc domes. Idk if your interested been trying to sell it
  2. I live in Lapeer Mi
  3. I am trying to sell my Banshee, just not that into it anymore and I know I won't get back what I bought and put into it. The frame is powder coated blue, the motor has new cases, trans, crank is new also trued/welded (stock) , cylinders are bored to 0.80 over but were re honed yes they will need to be replaced in a year or soo, new Wiseco pro-lite foraged pistons, pro design cool head w/ 21cc domes, intake boots are new, carbs had new pilots and mains put in. That's everything done to the motor, has itp hole shot tires on the front with itp rims new rear tires were put on in spring also itp rims. It has FMF SST pipes and FMF power core 2's on it. New throttle cable and twist throttle was also put on I'm asking $2,600$ ( I tried putting pic up but some reason they aren't showing) text 810-706-2395 If your interested and I'll send you pics. Thanks for looking !
  4. I never messed with the float height Bill put new mains and pilots in and however he set it is where it stayed I only took the slides out to put a throttle cable on. Soo I probably put them on backwards. Now your saying start with both air screws 1.5 turns out .? Cuz I don't have an air filter I have single air filter pods on each carb Sent from my DROID RAZR using Tapatalk
  5. How can I check if they are in backwards .? I'll do that in the morning .. would that also make the oil come out the pipes cuz the plugs are burning perfect it just doesn't wanna idle on its own Sent from my DROID RAZR using Tapatalk
  6. Noo I haven't taken the pistons out since I got it back from bill. Only thing I did was change the fly wheels and play with the carbs Sent from my DROID RAZR using Tapatalk
  7. Okk, soo the bike does start now it was the fly wheel. I had a stock one on and switched it to aftermarket and it would back fire but not stay running. Put the old stock fly wheel on and now it runs but I have to hold the throttle wide open to start it and then it'll run but if I barley hold the throttle open it holds a idle. I'm wondering what the air screws and gas screws should be turned out to or "stock setting" and I also noticed it smokes a lot and now I have oil coming out the exhausts at the end and also where the fatty pipes mount to the cylinders. The gas is mixed at a 32:1 ratio 93 octane and I used the ratio rite cups. Why won't it idle on its own now and why do I have the oil coming out ..? Gaskets and motor is new only 6-8 hours on everything Sent from my DROID RAZR using Tapatalk
  8. Noo it doesn't have a key switch. Just a off/on switch with the hi/low lights on it Sent from my DROID RAZR using Tapatalk
  9. If one of my wires were touching my pipes what would it do .? Because I'm still getting spark. Only thing I noticed is if I kick it over by hand when I check for spark there's nothing. But if I kick it real hard with my hand there's a spark. Still not starting tho ! Plzz help !! Sent from my DROID RAZR using Tapatalk
  10. Don't know how to put em up .. Sent from my DROID RAZR using Tapatalk
  11. Noo I don't lol .? All I said was I have a banshee .. Sent from my DROID RAZR using Tapatalk
  12. How bout 2,800 ..? Its got new rear tires now and white cut plastics Sent from my DROID RAZR using Tapatalk
  13. Skeeter I have 1k into the motor from Bill rebuilding it .. Really ...? Sent from my DROID RAZR using Tapatalk
  14. I got a banshee Sent from my DROID RAZR using Tapatalk
  15. Haha funny skeeter .. this bike is starting to annoy me tho ! Anyone wanna buy it .?! Sent from my DROID RAZR using Tapatalk
  16. What does it do .? Sent from my DROID RAZR using Tapatalk
  17. What's that .? Sent from my DROID RAZR using Tapatalk
  18. Lol ^ I did Sent from my DROID RAZR using Tapatalk
  19. What about the reeds. Been trying to figure out the problem for 3 days Sent from my DROID RAZR using Tapatalk
  20. Fly wheel key is in there. Could it be possible that the flywheel is torqued down too much .? There for causing the problem .. Sent from my DROID RAZR using Tapatalk
  21. As far as I know its an stock cdi box. But I don't get the back firing and when I check the plugs they are wet with what looks to be more blackish oil then gas but they smell like gas Sent from my DROID RAZR using Tapatalk
  22. Noo harness isn't burnt on the pipe. It catches like its trying to stay running then stops or it'll kick over and back fire. I even tried new plugs still did the same thing Sent from my DROID RAZR using Tapatalk
  23. Yes it is. The flywheel is aftermarket tho, not stock anymore Sent from my DROID RAZR using Tapatalk
  24. I'd have to ask Bill, it was one of his stock stators he wasn't using Sent from my DROID RAZR using Tapatalk
  25. Okk soo I had my banshee out a few days ago breaking the motor in. As most of you should know Bill rebuilt it. The cases are new, new trans and shift forks, crank trued/welded, Wiseco pro lite foraged pistons, cylinders honed (they are bored to .080 over) pro design cool head w/ 21cc domes, advanced timing +4° Anyway 3 breaking it in with a full tank of gas. It had about 1/4 of a tank left so I was riding it a little harder. I went to hit the throttle and it bogged out then caught itself for a second and then bogged out again for good. Thought it was the gas soo I filled it. Nothing, checked spark and had Noo spark. Soo I replaced the flywheel and stator that was the problem. Now that is new also. Figured it would start right up, buttt all it does is starts for a sec then dies. Or it will back fire out of the right side, soo I kick it a few times then it does the same thing out the left, kick it a few times it starts for a second again then dies, kick it a few times then it back fires out of both. The plugs are new, the squish it .047 Bill checked it. The plugs are wet with gas but to me it looks like its more oily then gas but it is mixed correct at 32:1 cuz it was running before ... But just doesn't want to start and stay running. We don't know what it could be. Please help, motor only has maybe 10hrs on it. I just got it back from him a week or two ago. And now this Sent from my DROID RAZR using Tapatalk
