Chukkinsod
Everything posted by Chukkinsod
  1. Here is a pic of the red plastic I have for sale ...$160 plus ship and pp. Front has a crack and back has a pipe burn but still look good.
  2. Methcub - text sent....., 375HP ....Ill take some pics tonight and post something in morning
  3. I have a full Front brake set up including master and lever for sale...PM if interested
  4. All still for sale. Also have other items I will post soon. Complete front brake set up with everything including master and lever.
  5. For some reason it states you cant receive messages.... Red ones I have are drag cut and front you see above....only lower fronts. I can text u pics
  6. See my post in for sale section
  7. see my post in for sale section
  8. Stock OEM seat with Cascade blue white and gray cover in great condition. Hole from a branch poked through on top right corner (2nd pic) other than that great shape. 120 plus PP and shipping.
  9. Also for sale a full intake package all as seen in pic. 34PJ Alcohol carbs with power-jets, K&N Pods, Throttle Cable, Reed Spacers, Boysen Reeds and Stock Reed cages, Intakes with crossover tube along with new gaskets. All have just been cleaned and are ready for install. I will send carb specs to interested parties set up for SB Cub . 350 plus pp and ride.
  10. You can see the Key Hole better in this pic
  11. Included in the sale, blue tank and shroud cover as well as OEM plastic grille insert and mounting bolts. I will post in another pic the hole drilled for the key to be mounted. These are in great shape. $150 plus ride and PP fees. There is a faint light spot on these.... top rear of the right side in picture *** Note Red plastics are for sale but not in this post (front and rear red drag cut)
  12. no you can only push down on the peddle while cracking the bleeder.....if you leave bleeder open when on the upstroke it will suck air back in.. you must close the bleeder pump it up crack on the down stroke.
  13. I found that I had to bleed the reservoir 1st otherwise youll spend all day pumping. You may have to re-start the process. Also another trick ...rubber hose large enough to fit over bleeder, 12 oz plastic pop bottle....drill a hole in the cap large enough for the hose or fuel line to pass through. Press the clear line on to the bleeder and bleed brakes... This will capture all bled fluid and it will not be on your floor and u can reuse. As long as you keep fluid in the line it will not back feed air ..pump away
  14. Do a search on Maxload bearing above...many topics on them and TZ as well. Will answer many of your questions on difference and why or why not to use
  15. Can shee: Just a heads up...our porta tree over 7K.. so not cheap. We are fortunate to be on private property zoned commercial with trainyard on one side and expressway on the other so no one to piss off. You don't charge people at the gate you ask them to have a ten dollar donation to support the track. After all is said and done, you will find having consistent people to "help" is where the struggle is....Grade the track, water , run lights etc.
  16. In PH myself ....never seen this bike at the track. Shoot me a PM on rear tire price/ roll out / paddles...look like 14 extreems.... HP not cock blocking...u got 1st dibs
  17. I have some TM38's with Billet bowls and powerjets...I believe set up for race gas (never ran them bought used) ....Ill PM some pics when I get home for you along with jetting spec and Price.
  18. Yogi a family campground with dumbass curfews and people that walk around with water and put out campfires. Havent stayed at Silver City in a while but that was a little less restricted. Val Du lakes much better.....less people. Last time we rented the entire back half for Mayhem in the mitten.
  19. My favorite..."im not into the multiple carbs thing". And "the frame looks tight"
  20. Keep an eye on the timing chain adjusters too...all fun and games till you skip a tooth on the chain and your valves smack the piston boogering up the valves, seats, head and piston. Rebuilds are WAY more expensive and many times require a machine shop for head /valve recut
  21. I since that was built I think two or three other people have owned. Still in Metro Detroit area
  22. And then there was light!!!
