sick421
Everything posted by sick421
  1. Jerry is top notch , a perfectionist if you send him work you wont regret it , it will be done right and professionally. But he does specialize in lt 500 and trx250r . I have 250r built by him and its a runner Sent from my iPhone using Tapatalk
  2. Check your reeds , a bad reed will cause a dead cylinder at idle Sent from my iPhone using Tapatalk
  3. Yeah get a nice a arms stock frame Sent from my iPhone using Tapatalk
  4. I would put in frame pipes and a shorter swinger and it should do fine . If its drag ported it will lack in the the bottom , and be too violent on the top . But it all depend on what caliber of a rider you are . I dune and trail a drag ported cub and i rip rocks at anything that is close behind me lol Sent from my iPhone using Tapatalk
  5. The 35s were airstrikers so 45 pilot , 150 main , 1 1/2 turns air screw , CEL in middle The 39s ended up with 55 pilot , 178 main , 1 1/2 turns air screw , DGH needle in the middle clip Fuel is 110 sonoco / klotz oil 32:1 Sent from my iPhone using Tapatalk
  6. Got my pegs and all i can say is BADDDD AS Fu**** Sent from my iPhone using Tapatalk
  7. Sent from my iPhone using Tapatalk
  8. LOOKING FOR +6 OR +4 ARCHED LINKED SWING ARM , ANY BRAND JUST CLEAN AND WORKING ORDER, THANKS
  9. I would switch the o ring on your seats, and replace the needle valve Sent from my iPhone using Tapatalk
  10. Thank its a drag ported cub Sent from my iPhone using Tapatalk
  11. well I been debating for a wile regarding switching from 35mm pwks to 39's for my drag ported 421. I even made a few posts in the past asking if it would be worth the time and money in switching to 39's, some said yes its a night and day difference other said no stick with 35's. well I finally made the jump , I just wanted to share some differences I noticed. first of all I think the switch is based on application and riding style, I noticed the 39's keep my engine a little cooler, it screams a lot harder on top and the band last longer too. but the negatives of the 39's vs 35's is bottom end loss. my motor mods are ( cpi inframes, 10in pods, +10 timing, 1cc domes on sonoco 110, vf4) the bike feels faster shifting at WOT but the rideability given from bottom end power went down. With the 35 pwks bottom and mild range power was amazing , the bike wouldn't stay on the ground, not that it doesn't get off the ground with the 39's but the torque hit was harder . The negative with 35's is only really is the over rev power falls off a little sooner. So if you are a 50/50 rider drag/duner like me the 35 pwks are king, if you lean more towards drag racing up the hill then 39's would suite you better. JUST MY 2 CENTS
  12. On my 421 drag ported cub with those carbs , i ran CEL needle , 152 mains , 48 pilots and 1 1/2 turns on the air screw. The air strikers is a richer carb it likes leaner jets . The air striker uses a # 4 rich slide vs the regular pwk uses a # 6 slide which is leaner. Also remember a bigger motor with smaller carb will draw more fuel through a smeller jet more efficiently vs a smaller motor. Sent from my iPhone using Tapatalk
  13. Money sent thanks Sent from my iPhone using Tapatalk
  14. Pm sent Sent from my iPhone using Tapatalk
  15. Like the title says need a billet rear brake rotor hub for a stock axle Sent from my iPhone using Tapatalk
  16. I tried a 48 and it felt like it was going to blow . Rpms were high Sent from my iPhone using Tapatalk
  17. I have a 4mil cub , drag ported , 21cc domes , running sonoco 110 , sb cpi inframes , vf4, 10in pods , + 10 timing . I was running 35mm airstriker and the jetting was perfect at 45p , 1 1/2 turns af, and 152m cel needle in the middle. Now i switched to 39pwks , and im running 158m , 1/2 a turn on a a/f , cel needle in middle , and 52 pilot. It runs like crap it had tons more power with the 35s . It idles a little high and the low to mid range sucks . Top end rips . All suggestions are appreciated . Sent from my iPhone using Tapatalk
  18. sick421
    Rear wheel hubs
    In need of cheap rear wheel hubs . Stock but will pay if you have a nice set of billet ones . Sent from my iPhone using Tapatalk
  19. Carbs found Sent from my iPhone using Tapatalk
  20. Pm sent Sent from my iPhone using Tapatalk
  21. Anyone? Sent from my iPhone using Tapatalk
  22. Like the title says , looking for 35mm pwk air strikers , pp ready Sent from my iPhone using Tapatalk
  23. Pm sent Sent from my iPhone using Tapatalk
  24. Like the title says , paypal ready Sent from my iPhone using Tapatalk
  25. Pm sent Sent from my iPhone using Tapatalk
