Lee_H
    Odessa, Tx.
    Red/white 04,TR6's. Blue 02, 421cub, Cool Head 22cc domes, CPI in-frames, 35mm PWK's, LSR +2/+1 A-arms, Elka's, Durablue axle, +4 swing arm, Red/black 02, stock with Fatty's Gone but not forgotten, 90 J arm
Lee_H's Achievements
  1. Lee_H
    Wanted: air box
    I am needing an air box badly, I'm looking for something around $50, nothing else left in the budget due to some unforeseen family expenses.
  2. $50 shipped for the air box?
  3. I'm in Odessa and we are at 3000', similar temps, air quality and humidity, on every one of my stock piped, no air box lid Banshee's, I have to run 310 mains, 4th groove and 29.5 pilots. Also don't confuse dynojet jets with stock Mikuni jets, they're not the same size jets.
  4. Get a 2001-up wiring schematic, its pretty easy to do. You will need a dual element bulb, a new dual contact pigtail, brake switch, brake switch bracket, brake switch spring and some wire.
  5. 99 4 mil cub CEL needles in the 3rd groove V-Force 3 reeds Nology coil +6 timing 40:1 1) What type of aftermarket exhaust do you have? Early CPI in-frames 2) What type of airfilter do you have? Dual K&N pods 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all No air box 4) What is your elevation? 2877 5) What size pilot jets are you using? 45 6) What size main jets are you using? 160 7) What temperature is your Banshee jetted for? 100 8) Do you have a port job? Light clean up 9) What kind of carbs? Keihin PWK Airstrikers 10) What size carbs? 35mm
  6. Stock bore and stroke 04 Needles are in the 3rd groove 1) What type of aftermarket exhaust do you have? Toomey TR6 2) What type of airfilter do you have? K&N 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all Stock air box, no lid 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 2877 5) What size pilot jets are you using? 30.5 6) What size main jets are you using? 320 7) What temperature is your Banshee jetted for? 100*F 8) Do you have a port job? No 9) What kind of carbs? Mikuni 10) What size carbs? 26mm Thanks!
  7. +1, all I ever did to mine was occasionally replace the bushings and ride the hell out of it.
  8. Me, I've resurrected many basket case bikes through the years. I end up stripping them to the bare frame and completely go through them. To be honest, it's really not that big of deal, you just have to know what you're looking at when you're considering taking on this kind of build.
  9. This was a very smooth transaction, no problems whatsoever!
  10. Lee_H
    R2 pipes or..
    All mounts should have weld pads on them when you're dealing with thin material, the fix would be to cut the mount off, plate the area, and weld the mount to the plate. Vibration, thermal expansion, and thin ga. steel are the key factors here. Do the repair to both sides, and send the pipes off to get them nickel plated, good as new!
  11. Lee_H
    Pistons
    I'm needing a cheap set of std bore pistons, long story short, all three of my shee's are down, I gave my stock bore pistons to a buddy, and now I'm in bad need of a set for my 04. Money is a little tight due to a string of bad luck, but I just want to get my 04 running so I'm not without a ride for the next few months .
  12. Best damn advise I've seen! I have 3 of these bastards, between them and my wife, I can't keep enough money to buy a coke.
  13. Do you still have the lights?
