Davidw
    2008 Orange Stock
Davidw's Achievements
  1. also forgot to add V4 reeds
  2. Yes I mixed oil with the gas, around 32:1
  3. Looking for some ideas on what jetting/needle to use on my shee Stock motor Stock Exhaust Stock air box with hole cut on the top exposing almost the whole filter 32:1 pre mix ratio 1250 feet above sea level 35mm Keihin PWK carb Trinity Single Carb kit all input is appreciated
  4. pull started it twice, definitely wasn't the best idea to keep trying to get it going when it didn't wanna start
  5. accidentally double posted please refer to http://bansheehq.com/forums/index.php?showtopic=165601
  6. Well first I will start by saying yes, a few stupid decisions were made that should have been thought out better. So basically I bought this banshee, that apparently only has 3 hours on it since a rebuild, and has sat for around a year. The seller started it, and I rode it to my truck to load it up, all seemed fine. I filled it up with gas and oil, took it for a ride, and I wasn't exactly easy on it. After fifteen minutes of riding the power seemed way down so I headed back to my truck to bring it home. After getting home it felt seized when i tried to kick it , I put it in gear and rocked it back and forward , that freed it up and I was able to start it. I noticed that there was only smoke from the left pipe, then it died and refused to start. I pulled the plugs and kicked it over, it felt like there was compression on both cylinders but this was just putting a finger over the spark plug hole, we also checked for spark and both plugs were sparking. One plug looked normal, the other was soaked in gas. We ended up towing it around with another quad while it was in gear, after turning the engine over for 15 seconds like that it ran for a bit then died. We towed it again to start it, and then my buddy decided to try revving it up, at which point it seized and would not free up this time. So I tore it down and saw this... (text continues after the pictures) What I dumped out of the exhaust pipe The cylinder of the problem side... The Piston The Crankcase of the problem side The cylinder that was working I'm guessing the connecting rod is probably jammed into the case on the side where the right cylinder used to be. If not then pieces of the engine probably got jammed in the bottom end somewhere. I'm not really sure what to do at this time. Is it worth it rebuilding this engine, or would I be better off finding a replacement? I'm also looking for some speculation on what happened to the engine when the one side stopped firing, when it seized the first time, and when it seized for good. I told you guys some bad decisions were made, looking forward to your guys' input!
  7. Well first I will start by saying yes, a few stupid decisions were made that should have been thought out better. So basically I bought this banshee, that apparently only has 3 hours on it since a rebuild, and has sat for around a year. I filled it up with gas and oil, took it for a ride, and I wasn't exactly easy on it. After fifteen minutes of riding the power seemed way down so I headed back to my truck to bring it home. After getting home it felt seized when i tried to kick it , I put it in gear and rocked it , that freed it up and I was able to start it. I noticed that there was only smoke from the left pipe, then it died and refused to start. I pulled the plugs and kicked it over, it felt like there was compression on both cylinders but this was just putting a finger over the spark plug hole, we also checked for spark and both plugs were sparking both. One plug looked normal, the other was soaked in gas. We ended up towing it around with another quad in gear after turning the engine over for 15 seconds like that it ran for a bit then died. We towed it again to start it, and then my buddy decided to try revving it up, at which point it seized and would not free up this time. So I tore it down and saw this... (text continues after the pictures) What I dumped out of the exhaust pipe The cylinder of the problem side... The Piston The Crankcase of the problem side The cylinder that was working I'm guessing the connecting rod is probably jammed into the case on the side where the right cylinder used to be. If not then pieces of the engine probably got jammed in the bottom end somewhere. I'm not really sure what to do at this time. Is it worth it rebuilding this engine, or would I be better off finding a replacement? I'm also looking for some speculation on what happened to the engine when the one side stopped firing, when it seized the first time, and when it seized for good.
