Abdul
Everything posted by Abdul
  1. it gets really really hot like 45c !!!
  2. Hey guys I have around 1000 $ , and I have a complete set of pipes (T5) and a pro flow kn airfilter. So should I buy the noss head and ,v force 4 reeds, a bigger radiator and a adjustable plate . Do you think that those mods will make a really big diff ?^
  3. So what is the diff between the two o f them?
  4. Pro desgin or noss cool head and what is the diffrence
  5. Any idea guys I need help what should I do , and the sound of the stock pipes changed. Its a new banshee 09' do I really have to do a rebuild
  6. Why is it cause of the airfilter or what help guys please
  7. + 1 , 2 , 3 there are fine but when I hit the 4th gear really really low rpm I dont know what happened any idea ? Does the idle have anything to do with this cause my brother turned it to the left I think o
  8. Hey I was installing my new O ring sooo I was so stupid I was supposed to use the drill put the nails so I used it and I drilled like 4 halls :/ and all of them didnt fit except for the last one . So I've installed it and finished everything , but there ia like 4 halls in the airbox what should I do ?? Please help guys . + it didnt fit like 100% I have to push the cage so hard to close it HELP!!!!!! Thanks
  9. yeeah I meant the pro flow kit
  10. Hey guys I've just got a k&n airfilter kit and it came with an O ring . So , my question is do I need light film or something to make sure that the O ring will stay in it place ?
  11. I have a k&n filter and t5 pipes
  12. pump gas , elevation : 2, 008 ft , 612m
  13. Are you serious guys ?? then any stock banshee is a 700
  14. Hey guys what should I take 22cc or 21cc domes or what , i am mostly in the dunes ! And what is the difference? ?
  15. then should I turn it to the left or to the right ? Can you explain it a bit more ?
  16. Hey guys My stupid brother turned this into the left I think but I am not sure . Can you tell me what is this exactly?? After he turned it , the bike doesn't stop it keeps moving even when I am not touching the throttle ???? I dont know how to describe it , its infront of the filter air box its like a small aluminum nail that u can turn it to the left and right ????? What should I do ?
  17. Hey guys finally I decided to buy the v force 4 reeds , so they said I have to rejit my carbs ?! What do they mean by rejetting my carbs and is it necessary?!! Thanks
  18. And do you think should I get 21cc domesfor my cool head ?
  19. do you think a car temp gauge will work ??
  20. I know it wont make me faster , but do you think it worth 135$?
  21. Heey guys I have 09 stock banshee this is the mods that I will be doing : 1-what should I get t5 pipes or cpi? , I am mostly in the dunes 2-K&N air filter 3-v-force reeds 4-radiator 40mm 5-cool head 6-adjustable timing plate +4 How many HP will come out of this mods ? Do I have to buy a flywheel puller and why ? Do you recommend me to buy a trail tech vapor ?
  22. Try to replace the sparks with new ones
  23. thanks , should I get the v-force reeds ?
