mx1986
Everything posted by mx1986
  1. mx1986
    frame
    ya this has been a pretty good learning curve. the first three times to the sand bar i think i lasted about 30 minutes and then i broke something but always something minor. now im working on a wheely bar. i should redo the front a arms cuz the geometry is off, but im ready to start a new frame now.
  2. mx1986
    frame
  3. mx1986
    frame
  4. mx1986
    frame
  5. mx1986
    frame
    I hear ya and i post some pics. I understand that the weights r equal but the strengh is where its at. plus i only weigh 145. The last frame I built was .083 mild steel tubing a arms and all except the main horizonal bar that supported the shock and the motor mount in the back I used bigger tube. The ten mil i built the frame around hasnt bent it yet, even when I ride a wheel the whole lenght of the sand bar. lol
  6. mx1986
    frame
    Ya that's y I was asking I put .o35 on my mic and its super thin. But the next step up is .o49 and that's to thick. I can weld anything with my tig so I know I can weld it. I just though someone woulda tryed it.
  7. mx1986
    frame
    It will be a full frame. I have made one out of carbon steel tubing already and want to move on to chromoly. The first frame I did was a double a arm. Had the geometry a little off. I just used blaster shocks for that. U know something cheap. This frames will be easier Cruz I know what I want to do and Single a arm is much easier to build than double.
  8. mx1986
    frame
    Also I want to know where u get the single a arm shaws.
  9. mx1986
    frame
    What thickness of chromoly is a good drag frame made out of. I'm building a new frame. I was gona use .o35 tubing. One inch for the main bars on top and bottom and 3/4 for subframe. Any advice would be great.
  10. Was wondering if anyone ever moved the airfilters away from the carbs and put a spacer pipe inbetween.
  11. I believe mine is .115 or .112 main jet but the dumps r .120 on my 38 pwk I think ur alright if ur main jet is smaller then ur dump Cuz ur main is only gona flow as much as ur dump allows.
  12. Have a Set of 35.5mm mikunis with billet bowls and cable setup for alky looking for a set 38 or bigger keihens or mikunis send me a text at 4023802298 with what you got
  13. For fastest response text me at 4023802298 Mikuni 35.5mm flat slide carbs with billet bowls and cable setup for alky in great shape 250 shipped rdz sb/sf raw same side 325$ shipped
  14. mx1986
    Rear marvin
    In need of a rear marvin Text me at 4023802298 with what you got and your price
  15. So r those CPI big bore big flange. Cuz that's wat my ten mil Rex has. If they r bbbf I'd be interested.
  16. Mikuni 34mm alky carbs bored out to 35.5mm with pods 200$ shipped Lsr axcailber axle with carrier, carrier is a little beat up works fine 250$ shipped Pm me or text at 4023802298 for faster response
  17. mx1986
    gear change
    I have a 16 tooth also maybe I'll try that to.v
  18. Depends what you have
  19. mx1986
    gear change
    ive got a pretty big tire with 80 to 81 roll out so im try 15 up front this weekend cuz i got it on my sand road. i got 14 41 on it now ands as soon as i hit second i pull the front wheels straight up in the and air.
