hawaiianbasshead
My Banshee (optional)
01 blue, FMF pipes, twist throttle w/TORs eliminated, durablue axle, spacers front and back, UNI filter w/adapter, AC nerfs, ITP T9 polished fronts, ITP baja rears
hawaiianbasshead's Achievements
Custom Hand Painted Front Fullbore Plastic
hawaiianbasshead replied to vifferman's topic in For Sale - Parts & Accessories
$50 for the skinney white gurl in ur sig -
got this stuff put a little work into it cleaning it up and decided to stick with my twist throttle for now... to use it for a tors eliminator setup if your carbs are stock you will need the idle screw kit http://www.ebay.com/itm/Yamaha-Banshee-Idle-Screw-kit-w-tap-drill-bit-/200356038297 and to drill/tap the stock carbs http://bansheehq.com/forums/index.php?showtopic=135591 looking to get $75 shipped for the setup, the throttle body itself isn't a great polish job but looks pretty decent. could use touching up. [email protected] is my email, you can probably search my name on the net, I have great feedback everywhere from car forums to audio forums to gun forums and atv forums that I'm a member of thanks for looking! Tom
any portwork? setup for the +4mil? who did the big bore/where would be the place to get the right pistons for them?
banshee's being a dick head...
hawaiianbasshead replied to banlee's topic in Banshee Repairs and Mods
electrical system or bad gas? I'm having issues with my 450 and it's either or both of the above, I can tell, well it was having issues with the wiring cuz I could wiggle certain wires and it would die and not start til I wiggled them again but now seems like it's bogging and popping like there's water in the gas too... notsure, could be just the wiring on my bike. good luck tho! I was just thinking what a pita it is to troubleshoot a stock 4 stroke with all the god damn wires and mine is the suzuki so the fucking fuel injection bullshit is even worse! but yeah, electrical or bad gas seems like a crappy connection in my case for sure doing some of the harm -
well shit, good deal then! I supported them before I even got my banshee so I'm out to a great start here on bansheehq LMFAO my concerns with it were nominal at best. just need to be careful putting the screws that hold the wire clips in. other than that it worked fine and besides no directions/installation instructions I have no complaints! but for the price hard to say. maybe a link to a short vid online would be nice or piece of paper with a pic showing where to line up your new timing mark... everything is pretty self explanatory tho really wanna try to dial my jets in better now tho and get some engine ice and a giant billet impeller see if the temp is down it's got a little more crisp of a feel and jetting it on point will ensure longer lasting motor and optimal power
huh, sounds familiar, my bike also has lack of power down low, slightly hanging revs then when I get up to 6th it kinda falls on it's face if not revved up in the powerband then when I downshift it seems to be on it's face as well unless in the powerband while in the powerband it screams but out of it barely runs lol I actually forgot which way to move the needle to richen it up so I raised the clip 1 setting on both but I think I just leaned it. I bought the bike and it was already like this, now I want to make it run better so I'm trying to figure it out. I DID add a timing plate and set it to +4* yesterday other than that all I did was put in new brake pads and change a bent tie rod end. this is my 1st banshee so I'm completely new to this. I'm not even sure where the air screws are I'm guessing under the carbs like a raptor 660? basically the stator plate was the most work I've done on this bike but I'm looking at solving or at least lessening the issue I have on it. and make it at least pull 6th, gonna drop the needles 2 clips to go richer than I was set as one plug seemed a little on the lean side for me when I just checked them.
um, east coast atv on ebay was like $35 shipped airmail to HI, my CC is maxed and it was all I had in ebay. otherwise a site sponsor would've been my 1st choice to go. I'm sure it would've came with support/instructions for install it also was tapped/threaded from the front side so the wire clamps are a pita to get in. it does not come with screws either and I basically had to drill out my stock small screws so I got new stainless ones from ace hardware chariot is on my list for a high flow impeller kit, not sure where to get engine ice locally but I think the shee running cooler would also help the crisp feel of it not sure... also I have alot of breakup when I try to get into 6th so I think it's jetting and I need to check it, even once I try to downshift back it seems like it's boggy in low rpms so maybe just needle settings but mains could be off too gotta check the plugs and see how they look. I don't have a jet kit yet as I bought the bike used so that sucks.
sweet, thanks, didn't wanna start it up and it was at like +7* LOL, thanks for the quick response! gonna give it a try soon as I can escape my lil one and put the cover and crap back on... 6:30pm so I got like an hour max of sunlight left... other mods are FMF SSTs and aluminum adapter with UNI filter and no lid, not sure on the jets I bought the bike modded, will see if it pulls 6th uphill now, it has a giant front sprocket so even at 135#s up a mild hill on the street it doesn't like to pull 6th for me LOL.
so I got a timing plate and put it on, I matched it to the casting line on the block because it was the only line I could find? is that correct? couldn't find pix or actual directions anywhere that specified that and the search was giving me bs about how I was searching... thanks for any help, wanna rip it up the road to see if it makes a diff lol
Aged Inventory Sale
hawaiianbasshead replied to Wildcardracing's topic in For Sale - Site Sponsors Items
still got tusk brake block offs? -
Sick bike for the price
hawaiianbasshead replied to dunesovertrails's topic in General Banshee Discussion
that's a killer deal coming off of hawaii prices lol. I suppose if I get a modded bike, I'm gonna pick it up somewhere other than here LOL and figure out the whole shipping deal... I've seen stock bikes here with bolt ons for similar asking price... I'd buy that in a heartbeat if it were local to me! http://honolulu.craigslist.org/mau/mcy/3131934572.html here's rubbish for more than that LOL http://honolulu.craigslist.org/big/mcy/3141688020.html found one looking for an ar15 trade so I might put together an AR and see. it's an 02 limited with Toomeys so probably better than my current 01 shee with an exception of mine having a crusty durablue axle lol -
V-Force 4 who already try it
hawaiianbasshead replied to Banshee SE's topic in General Banshee Discussion
quick someone sell me their v3s for $50 before they're worthless, offers only good til before september -
I was eyeing the works shocks, fatbars and lights too lol. could be wal mart car fog lights the $25 ones but still those are possibly trail techs I'd scoop it!
revbox and stator plate
hawaiianbasshead replied to falcon gt351's topic in Banshee Repairs and Mods
I don't think the ignition boxes are worth anything, otherwise more people would be recommending them. I'm gonna get the timing plate and call it good... on a raptor I like having no rev limit in reverse but that's the only real thing I've had an aftermarket CDI for... oh, and I got it cheap so it was worth trying and was alot easier to reverse on hills and anywhere really LOL just had to be a little more aware
