hunt3rm008
Everything posted by hunt3rm008
http://www.ebay.com/itm/171093074633?item=171093074633&viewitem=&vxp=mtr
my bike runs fine and everything but it is very boggy and does not have the power it should, it does have power but i feel something is stopping it from being what it should be. my bike is completely stock i just rebuilt the top end and got a little port job, nothing major. i am running stock pipes, stock carbs, stock jets, and no lid on my airbox. is it my stock pipes? i feel like it has power but cant let it out because of the stock pipes
i found jets on the intake hole of my carbs.. they are stock carbs. but when you look at the intake side on the bottom of the circle there is a jet. those jets are different sizes.. is that bad? what size should those be? one is 30 and one says 1.6 .....??? and also on the carbs, on each carb on each side there are like those breather holes, are there suppose to anyhing attached to those? im not talking about the choke ones, i got those connected
do you mean the jug gasket? and no he did not and no i did not do a leak down test.
any ideas on the starting issue? it still wont start right now i just tried. and when i give it a little bit of gas while kicking it over, it sounds boggy.
yes the smoke problem is fine now, just the low compression, and starting problem. it starts up cold fine, then i ride it for a few minutes and shut it off. and immediately after that it will not start up. until about 30mins later.
i did use equivalent to re seal the cases and yes i went across the back of the crank, i watched jlsparky7's videos on youtube. he has many banshee videos. and what do you mean by the plugs on the bottom of the cylinders? nothing is leaking on the cylinders.
i sent my cylinders out to herr jugs racing and got the cylinder bored and honed to the next size and ports cleaned up, and kevin from herr jugs sent me back a top end rebuilt kid.
when i do a cold start it will usually start up and run. then if i drive it for a few mins then shut it off. it wont start back up. i have to wait a little while.
so first off i did a topend rebuild and once i started it up, it smoked a lot and burned oil. so i split the cases and replaced all the seals. one of the crank seals was the problem because it was damaged. so i thought this would correct the problem but i guess it didnt. after putting the new seals in and starting it up, it smokes a little bit, barely so i think its okay. but the compression is only at 100psi. and my elevation is 470ft. also when i try to start it, sometimes it will start first kick, then another time it could take over 30 kicks. another thing is after replacing the seals, i reused the metal head gasket. could that be my problem? could reusing that cause the problems i am having? i would appreciate any advice or info, thanks everyone
http://www.ebay.com/itm/170974342664?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
What does going to a 4mill or 10 mill actually do? I know it's a different crank but what specifically changes? Do you have to change the cylinders or pistons? Can you run a 4mill on a stock top end? What are the performance advantages when going 4mill or higher
http://www.ebay.com/itm/170948161081?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649 CHEAP
http://www.ebay.com/itm/170948140650?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
need help putting my chain slider on up in front
hunt3rm008 replied to 209 banshee's topic in Banshee Repairs and Mods
This happened to me , If you have an air hammer grab a chisel tip that not bigger than the swing arm bolt and it has enough power to push it through -
i havent run it enough for the plugs to get any bad, after i rode it and checked them out they were a little dark and wet. i just read alot about jetting and found out when your rich it could produce thicker exhaust smoke. my banshee is bone stock and stock mains are 200 and i just cleaned my carbs and my mains are 220 and pilots are 25. could i be really smokey because of my jets being 2 sizes up? i havent had the chance to ride it yet but i will be riding it friday and i will let everyone know how it runs and ill take a video of her running and pics of my plugs, thanks everyone for this help
My plugs are clean when I took them out they just were wet and smelt like gas.
This might sound stupid but how do you tell if it's running rich or lean? Also the compression isn't my only problems it still smokes a lot out of the exhausts . I replaced the head gasket so it shouldn't be burning coolant so does that mean it's burning gearbox oil? Or could it be burning all the two stroke oil that leaked down into the crank area from all the lubricateing I did while rebuilding the top end? If I rip on it for a while, and it is burning gearbox oil, will that harm my motor?
Yes I did
i did not check the compression after the rebuild so i am not sure. should i just rip on it? i thought you had to baby it for the first few hours
is it smoking alot because it isnt broken in yet?
And I am not sure if it's burning oil or coolant. My coolant levels haven't gone down noticeably. How can I tell if it's oil burning ?
The reason I rebuilt the motor was because I Bought it as a roller with the motor out and the motor had the top end pulled off. The kid just said it needed a new top end rebuild . Breakin it in I started it up and let it idle til warm and Shut it off to cool and repeated that a few times then on the 5th time after warming up I rode it very slowly not giving it much gas for 10 mins then let it cool and repeated that process babyin it.
where are those seals located? and how much is a leak down tester? what would that check for? leaks throughout the whole engine?
i rebuilt my topend a month ago and have only rode it for about an hour total so far because ive had so many problems with it. i sent my cylinders out to herr jugs racing and got them bored and honed with the piston kit. i put it all back together and it started right up but smoked A LOT. i thought it just had a bad head gasket so i ordered a new one and put it on, and it still smokes A LOT. i decided to check the compression and it did not go past 107PSI. i read that stock is usually 120-130 and anything with 110 or lower needs a rebuild. why is my compression so low? its freshly rebuilt. it starts up always on the 1-3rd kick. also my spark plugs were pretty wet when i checked them. the motor is completely stock besides being bored over to the next size. anyone know whats going on?
