Jbeck103
Everything posted by Jbeck103
  1. ha I know i just got carried away in the making of the tread! They dont let you on the track without all the safety gear on and even with all the proper safety equipment things can go wrong.
  2. So its been 2 weeks now since I was riding my banshee on the flat track, got a little too far sideways, and rolled her a few times! Only damage to the quad was some bent bars, to me I got a nice broken collarbone sticking outta my skin! On the fast track to recovery eager to get riding again. Basically I wanna hear other stories of hospital trips/injurys that come from riding the fasted quad made! So lets hear some lessons that you gotta learn the hard way!
  3. Turns out the manual torque specs werent quite enough! I just went around all the nuts on the head and gave each a few more degrees with the wrench and it sealed it right up, makes me feel better now i can get break it in and ride it already!
  4. Yes brand new headgasket, came with a full gasket kit. I used the proper torque spec. and procedure too. Tomorrow im gonna snug the nuts on the head down a tad bit more if all it needs is to get squshed that little bit more.
  5. Just put in a new top end on my banshee. Its runs fine but has a coolant leak coming from the headgasket coming through the UP sign on the headgasket on the inside of the motor??? Anyone ever come across this? Only leaks when system is pressurized.
  6. its got trinity 2:1 intake with a single keihin pwk 35 mm carb. Trinity Stage 4 pipes, no porting has been done. Sitting at just under 1000 ft elevation
  7. Rejetting my quad for this summer. The only part im having trouble with is which pilot jet I should order. Currently in the bike is a 55 size jet and will not idle from the extra fuel its getting, so i am bringing the size down. They sell them in sizes 52, 50,48,45,42,40,38. Since I have to order id like to get close the first try. Any advice would be great. Thanks!
  8. Thank you very much for the information. I looked around the internet and everyone else said the same thing. Its weird that i never had a coolant leak before the rebuild??? Unless they fell out uppon dissasembly....either way ill have them ordered by monday so i can finish my build! thanks much!
  9. Was putting together my top end and i was reading in the service manual theres a rubber coolant plug on each cylinder that goes on the exhaust side. When I took it apart i didnt see anything like that and so am wondering what will happen if there is no plug in there? Thanks
  10. Just got my cylinders back from machining and there not .040 over. Just wanted to know if anyone has done the math and know off hand what cc i am at now. thanks
  11. For the sprockets i just buy the JT sprockets off of ebay for like $20. Ive got a 12, 14, and 17 tooth and different length chains for each. The sized you kinda gotta play around with, it kinda sounds like youve got two different riding ratios. For dunes i would want a high top speed but not too much that it takes away youracceleration, and for trail riding it would be the opposite. If i had to throw some numbers out there id say go maybe a 13 for trail and 16 or 17 for dunes. If you only wanted to have one sprocket then id keep stock, but this is just my opinion. For chains i havent messed with them very much so i wouldnt be a great advice giver on that!
  12. When I drained my oil outta my quad i noticed it being a little milky so i can only assume its the 0 ring that goes on the coolant hose that connects the water pump to the head. My question is if anyone knows where i can get an exact replacement one for it? I dont want to have to just go to the hardware store and pick anyone out and hope its right because clutch cover gaskets can add up over time $$$! Any help would be great thanks!
  13. Running a higher onctane is not a big deal to me at all. The crankshaft if the only thing I am worried about with deciding dome sizes. I am at 900ft altitude
  14. Trying to decide what size domes to order for my quad. As far as I know my crank is completely stock and dont know what compression they will hold up to? I wanted to go 20cc but dont want to if I have to remove the crank. Any comments would be greatly appreciated! Also what is stock head cc???
  15. If i get the stock head rechambered though how small of a dome can i before i would acutally need a cool head to control the higher compression temps? I wanted to get to a 20cc domes
  16. Ive never heard of wildcard or the option of machining the stock head. Do you have a website or phone number I can call about it?
  17. Thanks very much! What is your reasoning behind the 23-24cc domes? Just curious
  18. Just got my banshee motor apart last night to do a top end rebuild and noticed very hard pitting on the cylinder head, I am going to replace it but cannot decide which path to go. The paths are buying another stock one for $60 or bump up to a cool head? And if cool head what size domes should I go? Mods I have are TORS delete, adjustable timing plate, Single Keihin Pwk carb, 1 into 2 intake, trinity stage 4 reeds and pipes, K&N filter with drilled airbox lid. The elevation I am at is just under 1000ft. Will the domes make a huge difference to stock? Is it worth the $100 extra? Thanks!
  19. Rebuilding my motor this winter and was wondering if its worth it spending the extra money for the wiseco pistons versus WSM pistons which come with a kit I may be purchasing. Wanted to know what the wiseco has over other pistons made for banshees???
  20. If youve got money in the motor id reccomend using transmission rebuild grease instead of regular wheel bearing grease. Worth the money when you look at what you got into the motor...
  21. At around 800ft
  22. Currently running trinity stage IV pipes, reeds, single PWK 35mm carb with single in dual out intake, and K&N intake. Rebuilding the motor this winter and was gonna see if anyone had any suggestions on what pilot and main jets would be a good idea to run. I havent had the motor or carb apart yet so I have no clue whats in there currently but all I know is that it wont idle at all. Any suggestions would be great thanks!
  23. So theres a few questions in this topic here. This coming winter I am planning on giving my quad a fresh top end to her. As of right now I am planning on going through www.fullboreonline.com for there top end rebuild kit with the WSM FORGED BANSHEE RACE PISTONS. One question was if anyone has had anything done by them and any comments would be great! Another question I had was I wanted to get a little more bang out of the motor so I figured while I got it apart I might as well put some smaller domes in there and bump up the compression. Another question was what size you think I should run? I was thinking about a 19cc (dont care I already run 112 octane). The next question was if I can install aftermarket domes in a stock head? And if I can do it without a machine shop or anything like that? Any advice would be great! "I wanna go fast!" Mods:Trinity 2:1 intake, stage IV reeds, Stage IV pipes, 35mm PWK Carb, Adj. Stator
  24. Did the hubs on the banshees stay the same size through there entire run or did the bolt patterns change over one year? Are they all 4x115mm in the rear?
  25. Just wondering would warrior and blaster rims fit on banshee hubs or are they different in size. The reason Im asking is I need new front and rear rims for my banshee badly and if I can get some warrior or blaster rims for cheaper than posts that say "banshee rims" it would be awsome, but if i gotta bite the bullet and spend the money I will just have to.
