Uf21
    2
Everything posted by Uf21
  1. So that like $14/month. Here in australia we pay about $40-60/month so what you guys pay is fucking cheapppp Right now I go to fitness first (maybe you guys have that in the us?) and I'm paying $70/month and have access to all fitness first gyms in australia.
  2. What the average cost per month for a gym membership?
  3. How about just getting a gym membership? I bet you didnt think of that one....
  4. Doesnt the caster oil leave a sticky residue where over time it builds up in the engine? Why dont you guys also state what ratio mix you're using because he'll probably ask that next lol
  5. Carb bowls aren't swapped, I'm sure of that and it already has a 27.5 pilot.
  6. To pull the coil cover off do I need to buy any special tools? Ill trying swapping cdi's and yes I use the choke when cold starting.
  7. what do ya spark plugs look like? I've already tried new plugs. Still the same. when its running, does it run fine? Yes runs perfectly fine and starts one kick when its even slightly warm. check your coil and stator: How do I go about doing this? what other mods, ? just pipes n rejet? DMC pipes, K&N filter with lid on and no holes. With jetting I will do a plug chop when I go riding hopefully this sunday.
  8. From the "bike is a batch to start" thread. OK so I checked compression. It's shows 110 on both sides. I tested it twice. I also tested it on a friends bike, his bike starts fist or 2nd kick and he's also reads 110 on each side. Is 110 still good? Why is mine hard to start when a friends has the same comp and his one is so easy. What else can I check?
  9. My shit only goes one way, and that's out. So you're outta luck.
  10. OK so I checked compression. It's shows 110 on both sides. I tested it twice. I also tested it on a friends bike, his bike starts fist or 2nd kick and he's also reads 110 on each side.
  11. Thanks all I wanted to know. I bought a compression tester on ebay and waiting for it to come.
  12. What's wrong with the question? I'm trying to diagnose a problem. Maybe with low compression it's hard to start even when the engine is warm. Maybe not.
  13. Just a question. If it is low compression is it hard to start when the engine is warm and cold?
  14. Isn't the out of frames just as loud hence making then a "faggot"?
  15. Also would a 14mm deep deep thread compression teseter give accurate results? The br8es is 14mm diameter by 20mm depth right?
  16. Oh thats only with the stock exhaust. My packing fell out on my DMC's and that was so loud it was giving me a headache (with the helmet on). Imagine it was off from the silencers.
  17. This happens. http://www.youtube.com/watch?v=ps0jcdHKu4o Too loud, too annoying.
  18. So has wack a shrimp on the barbie but that would seen odd to you guys.
  19. Now that's an odd one lol
  20. Will any compression tester do? thinking about getting this cheap on on ebay http://www.ebay.com.au/itm/Engine-Cylinder-Compression-Tester-Set-Kit-Tool-Test-M10-M12-M14-M18-Gauge-/200929778347?pt=AU_Car_Parts_Accessories&hash=item2ec8591aab What is normal compression and what's considered low?
  21. Calm down princess. Don't get your knickers in a knot.
  22. and wtf is BFE?
  23. If the compression is low, can or will it damage anything or cause more problems?
  24. What reeds you got?
