mike0chek
Everything posted by mike0chek
  1. i know the axle is the proper way but the tusk hubs are real nice and very easy to install, also just throwin that out there ha
  2. looks awsome dude!
  3. im running tusk extended hubs in the rear (+3) and just flipped my front rims around the they are almost the same width, i also have some custom brackets made in the front that drop the front end and widen it a bit more, cost me about $150 total.
  4. i learn something new every day lol
  5. i run 165 mains and 52 pilots on my 421, mods are below
  6. that cant be good for the crank havin different size pistons lol
  7. meanest warrior ive seen yet
  8. all depends what you want more, top speed or more low end. its nice to have a few different sprockets kicking around so you can try a few and see what you like best.
  9. call kevin or jeff, they will get you setup properly.....
  10. im runnin bear claws now lol holeshots worked good for me in the past...
  11. awsome! way too get them on the 2 strokes at a young age
  12. the green is awsome!!^^
  13. that turned out real nice
  14. very true, i have some 35 pwk's and they are great to tune.
  15. if you have some sheet metal and something to bend the corners with then its a piece of cake. all i did was make a box with an open top and open front. i made it too big so i could keep trimming the tops of the sides till it fit right. hope this helps
  16. im running pod's and made my own type of air box out of alum sheet metal, it not mounted but i made it a tight enough fit that it just slides in front under the back of the seat and seems to stay in there fine with a couple ties.
  17. alright guys thanks.
  18. here they are guys: http://www.farmandsandtoys.com/partdetail.asp?partid=119 says it will work on KEIHN carbs
  19. ill find it right now larry
  20. im pretty sure when i was talking to jeff i told him the carbs i'm running, i could be wrong tho, ill have to check the site to see if theres any info
  21. hey guys just got a pair of those adjustable carb tops from fast racing, is there any trick to installing these? like can they go past full throttle or will they just max out inside the carb? any input is appreciated! also im running 35mm pwk's
  22. shit that sounds fun as hell haha
  23. looks good man
  24. most guys will tell you to do a chop. playing with your mains should give you some results.
