hey so i have an 01 banshee. it has the tors removal kit. the key switch is gone and as of an hour ago so is the run/off switch. i removed it cause i thought it may be the issue. but here we go. it started up yesterday in the like 20 degree weather after about ten minutes of trying. rode it around all day had no issues. well today i adjusted the air fuel screw because it was running really choppy. once i adjusted the screw to 1.5 turns out and 2 turns out it wont run. if i pull it with my jeep it will fire up. but it wont kick over. even after pulling it and running it if i dies out which it is trying to do as soon as you let off the gas it wont kick over again. i pulled the carbs cleaned them up. everything was suprisingly clean inside. it has 310 mains 25 pilots and the needles on the middle clip. i synced the carbs back up. it will not start. i checked the wires. the black and red is connected. and the black and black white wires from the run switch are not. (im gonna put a tether on it) so everything is good. it should be firing up. but nothing. it wont start with choke half full no gas with gas nothing. the filter is clean. the compression is like 130 per cylinder. the plugs are brand new. when i pulled the plugs from it running earlier from pop starting it they were a nice creamy brown color. so the jetting should be okay. any ideas? im about to go nuts. my foot cant take anymore kicking. i pulled a plug out and like an idiot held the boot while kicking it over, it shocked the hell out of me. so i believe it is getting spark. i didnt realize that i was low on fuel so i switched it to reserve and put some more fuel in it. fuel line is clear and flowing good. idk if it is a wiring issue or what but please help!!!
