hi, dimwit here.
I'm trying to figure out what the "best bang for ya buck" shock would be for me. I only ride trails, alot of rutted out and rocky type of stuff, no real techy tight woods, more flat out ridge lines and fire breaks, i spend alot of my time in 4th-5th gear band hoping not to hit a rim buster. I'm not into jumping or mx. I'm too old for that shit (36) and the last 15 years on DH mountain bikes, mainly banshee's, have my ancles and wrists floppy as fuck, if I sneeze without bracing i fall flat on my arse .
because of that reason (no jumpijng) i'm thinking I dont need a rezzy shocks, opinions?. even though my standard shocks atm fade with the riding I do, is that cause it's a shit shock in general, or because of heat build up, or emulsion(frothy oil), considering this would rezzies be worth the extra $$$?.
I've been looking at banshee shocks for a while, and have found most of my info lurking here, but living in oz this stuff is EXPENSIVE, I will most likely order from the states so I need to get this right as it's roughly 150p+h, so sending them back to get revalved ect would be prohibative to say the least. alot of stuff I see have a pretty broad weight range ie. 110-160lb mx or 130- 200lb rec trails for the one pr shocks. It would seem to be a pretty broad range, is this range all covered with preload? cause the shocks I've been looking at aren't adj comp + rebound. Or is this just ebay marketing, tryin' to flog as many as possible, to people that can't be fucked asking someone that knows? everthing I've learnt about mtn bike shocks tells me that preload can't cover that much weight range. the reason i ask is cause i dont want to cough for adj comp and rebound shocks if I don't have to. I was hoping to get my shock valved for my weight exactly, not a weight range. I've been 190lb for the last 10 years and that aint changing, so why should i bother with adj comp and rebound, it would only be handy for intial setup wouldn't it? once I had my mtn bike shock dialed in i didn't touch it. Am I missing something?
only looking at front shocks for now. But are the std rears any good? I see they have adj comp and rebound, what can you do? rebuild revalve ect? or not worth it. I have seen revalve kit's online so if it's a matter of revalving it to my preference, I can do, I think, I don't mind fiddling around. I've done bike ones, 5th element's anyway, no nitrogen in them though. nitrogen charge doable for backyarder?
last thing I'm on a fairly strict budget mid 30's=mortgage, ect ,not alone there I know. Not long (2wks) after i bought my shee I barrel rolled it down a hill (steep learning curve + steep hill = carnage) so have been replacing everthing i bent, not planned for upgrade$.
So it was stock standard, now has a +2 rear axle and +2 +1 fullflight A-arms (i like hiem joints), it kind of worked out allright cause now I have to get my handling sorted first, rather than just go for bulk power upgrades as per usual.
if I could get something that suited me for around $800 that would be good, what should I be looking at? brands? models? sellers?
I think for shocks I would like to stick to new or rebuilt to new specs by a repped builder.
any feedback is great, steer me in the right direction.
