bansheeyfz450
Everything posted by bansheeyfz450
  1. I've been having a over-heating problem. Yesterday i put the Chariot Ultra Flow Kit, ASI over-sized radiator, ASI silicone hoses, and Engine Ice. I haven't taken it out yet to know. I would think i crossed all the bridges. But ???
  2. Dumb ?, how can you tell if you have fluid movement in the radiator. (assuming you don't have clear hoses)
  3. No, I didn't. But it had 13/41 gearing on it. And actually the chain tensioners are the same as b4.
  4. Center to Center? Center of front/rear sprocket? Where would I find a chain calculator?
  5. the long bolts are almost all the way in. which i guess is maxed out.
  6. stock is 14/41. I didnt think 14/40 made that much difference, but maybe it does?
  7. Everything on the rear is new. front/rear sprocket, chain, swing arm bearing, axle bearings, axle, front/rear chain slider, rollers, brake disc. Also maybe i should have mentioned this, gearing is 14/40
  8. I haven't tightend it yet. I was sitting on it and I had a buddy wiggle it. about 2 inches of play. I'm thinking of taking out a link. stock swinger/104 chain
  9. never done that b4, great idea. I just figured it would be easier on there, guess not always. I am now guess my chain is to long.
  10. yes its a new x-ring chain. 104 is to long?
  11. The 2 chain bolts are almost all the way in.
  12. redid the the whole rear, stock swinger. how do i tighten the chain? This is what i did, pulled the axle carrier out, tightend the to bolts (chain tightening bolts) went on one ride and now chain needs to be tightend again. do I just back out the 2 bolts? Yes I did sinch the nuts. Thanks
  13. What is the best/easiest way to flush the coolant out. I just bought Chariot impeller kit, oversize radiato, silicone hoses, block off kit. Redoing the whole cooling system. Also I am going to run engine ice.
  14. cool, thanks
  15. Going through the cooling system, putting in over-size radiator, silicone hose, chariot impeller kit. How much coolant (engine ice) do I need to buy?
  16. ASI radiator/silicone hose. anyone use or have experience with there products?
  17. anyone know if CV4 caps fit the banshee>?
  18. I am looking for High Pressure, thanks tho
  19. 1.6/23psi
  20. I was looking to replace my radiator cap. Wasn't sure which one to buy. High pressure cap, 1.6 good enough? Who has them and price? I see some on ebay around $20.
  21. Just got the axle, looks good. But the allen bolt on the 3-piece broke off inside! Cheap materials. I hope they'll exchange it for free. Anyone else have this problem?
  22. Mull engineering has a better impeller then Chariot?? I see chariot has to one at $55(standard) and the other at $105 (mega) For the money which one is the best?
  23. If I did that whole setup, is all under the water pump cover? Will it fit under the stock cover? Or do I need to pull off the clutch cover?
  24. I'm looking at changing the stock water impeller, ez drain, and timing plate. Pro Design or Chariot and WHY? I see a lot of people running Chariot but what about Pro Design? I see that Chariot isn't billet (impeller). Doing the research I see there real no price difference.
