bansheemandan
Everything posted by bansheemandan
  1. i lost my job so my toy has to go $4000 2000 yamaha banshee, completely rebuilt from the ground up, has about 7 hours on it since built, very fast, i have clean clear title in my name, everything is new or rebuilt motor k&t ported (drag port) 4mm stroker crank wiseco stroker pistons shearer inframe drag pipes pro design cool head with 20cc domes (pump gas) reed spacers boost bottle v force 2's 34mm keihin carbs upp intakes upp carb to air box adapters pro design pro flow air filter adapter k&n air filter air filter outter wear new shift forks wiseco clutch basket barrnet clutch pro design water pump impeller pro design adjustable timing plate all new bearings-seals-gaskets case saver powder coated cases (candy blue) chassis laeger pro trax +2 +1 a arms works triple rate shocks with rezzies g force chrome extended axle billet tie rods billet axle carrier everything powder coated--frame-aarms-swing arm-steering stem-hubs-brake pedal full chassis polished nut and bolt kit 5.5 ims gas tank 909 handle bars braided brake lines rpm bumper rpm grab bar rpm swing arm skid plate rpm full chassis skid plate foot peg kick ups shock covers itp ss rims rear tires (pure sport realtor) front tires (pure sport bandits) new front and rear brakes new chain and sprockets msr levers all new chassis and suspension bearings clutch cable throttle cable polished aluminum (dress up) tail light cover stator cover clutch cover clutch cover insert warter pump cover radiator cover master cylinder cover billet thumb throttle assm. nut and bolt kit gas cap cylinders cool head reed spacers handle bar clamp levers e brake block off tie rods
  2. also you should be a min. of 1 turn out on the air screw
  3. put a bigger pilot jet in, i am at 600fas and i have 55 pilots and air screws 1-1/2 out
  4. i bought a set from josh z
  5. need upper and lower engine cases for a banshee
  6. a pair of vforce 2's for a banshee, they need new reeds, best offer, pm me with offer
  7. still looking for one, i got screwed the cdi that i bought was no good
  8. stay away from rm stator
  9. i want to thank everybody for the help, it was a bad cdi box, it was a rm stator cdi box (go figure), as soon as i seen it was a rm stator box, i took my harness and box off my banshee and tried it on my brothers, it ran perfect, i bought the quad running bad, and i got it cheap because of the problem, so far i only have $350 into it, so not a bad deal, how is rm stator still selling this junk
  10. need a good working cdi with the round plugs, 1987 to 1994, let me know what you have and how much
  11. i just noticed it has a rm stator cdi on it, i have read a lot of bad things on them, i have been messing with the quad, i just put brand new vforce reeds in it, it runs better but it will not rev, when i take it for a ride, it will not kick into the power band
  12. i tried a different stator and coil from a running bike, i still have the problem, can it be a bad cdi, i always thought that if a cdi is bad that i would not even run
  13. i am starting to think that, do you know if and how there is any way to test it
  14. it is a electrical, not carbs, if i switch the plug wires from one size to the other it will do it in each cylinder
  15. thanks, i tried doing that but it is still the same, any other suggestions, my brother is driving me nuts and so is the banshee i am very greatfull for the help
  16. yes it has 128 in each cylinder, it was doing it on the right side, i switched the plug wires and now it is doing it on the left side
  17. hi, i just bought my little brother a banshee, it runs fine at idle, but will backfire every once in a while, and has no top end power, it will rev up, but not the way it should, i belive it is electrical because i switched plug wires and now it seems to be doing it in the other cylinder, i pulled the stator cover and the whole timing plate was loose, i tightened it up and set the gap on the pickup to .020, the pickup does look like it was hit by the flywheel a few times, but it does still run, the woodruff key is good, i am kind of thinking it is the pickup or the coil, can you pros tell me what you think and how to check the electical parts,, thanks in advance
  18. yes they are the same tires, but mine are new and not less then 1/4 thread like the tires on ebay
  19. try and find them cheaper, if you can even find them
  20. i have 2 pairs of pure sport realtor tires, 22x12x10, brand new never mounted, $300 plus shipping a pair
